Ovens Logo
A
Anonymous Posted on Jan 18, 2018
After replacing the element in our oven, we tested it out and the oven heated up fine. Later that day we turned the oven on again and there was a loud popping sound. Now the oven will not heat up? Could the element we just bought be faulty or did something more serious happen?
Vladimir Frolov
Level 3:
  • GE Master 2,075 Answers
  • Posted on Jan 18, 2018
Vladimir Frolov
GE Master
Level 3:
Answers
2075
Questions
Helped
415444
Points
6445
5 Related Answers
A
Anonymous
  • Posted on Sep 29, 2007
SOURCE: Oven problem
microprocessor burned out? There was a problem of this with the double ovens, after the top oven went through a cleaning cycle.
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 10, 2008
SOURCE: heating element in GE Range Oven
get the model number and order the exact repacement bake element
Anonymous
  • Posted on May 16, 2008
SOURCE: Oven made a loud noise, pop, and then black smoke....could heating element go out?
sounds like it blew a fuse or the heating element burnt out on it,look to see if the element is burnt in two
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 30, 2008
SOURCE: Faulty electric oven (Ignis AKL828/AV)
I think you will find that it is the oven element that has shorted, causing the trip to go. The fan will still work, but with no heat.
Remove inner rear panel of oven, there you will see the element.
Remove and replace.
Plz rate my solution.
Thanks.
Anonymous
  • 1136 Answers
  • Posted on Jun 20, 2009
SOURCE: maytag electric oven - MER5770AAQ. lower heating element not work
Hi, Unplug the oven and remove the element to test it. Check the element and see if there is continuity. If the element is open, replace it. It can be bad even tho it doesn't appear bad.
I hope this helps you.
Vic
Roper oven model FEP310GW0. Oven will not heat
If your Roper oven is not heating, there are several possible causes. Here are some steps you can take to troubleshoot the issue:
  1. Check the power supply: Make sure the oven is properly plugged in and that the circuit breaker hasn't tripped. If the oven is getting power but still not heating, move on to the next step.
  2. Check the heating element: The most common cause of an oven not heating is a faulty heating element. You can test the element with a multimeter to see if it's working properly. If the element is faulty, it will need to be replaced.
  3. Check the temperature sensor: Another possible cause of an oven not heating is a faulty temperature sensor. This sensor regulates the oven temperature, so if it's not working properly, the oven won't heat up. You can test the sensor with a multimeter to see if it's working properly. If the sensor is faulty, it will need to be replaced.
  4. Check the oven control board: The oven control board regulates the oven temperature and controls the heating elements. If the control board is faulty, the oven won't heat up. You can test the control board with a multimeter to see if it's working properly. If the control board is faulty, it will need to be replaced.
  5. Check the oven thermostat: The oven thermostat regulates the temperature in the oven. If it's not working properly, the oven won't heat up. You can test the thermostat with a multimeter to see if it's working properly. If the thermostat is faulty, it will need to be replaced.
If you're not comfortable troubleshooting the issue yourself, it's best to call a professional appliance repair technician to diagnose and fix the problem.
Jan 31, 2023 • Ovens
Chef Select oven (2000 vintage, manual controls) won't heat up properly. Heats to about 70-80 deg. but no more. Suspect either the element or thermostat, any ideas?
Or Why does it take the oven so long to bake?
When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element
The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard.
When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity.
Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced.
Why is the oven temperature incorrect?
The oven temperature control is usually controlled by a thermostat that uses a capillary and liquid filled bulb. When the bulb's liquid gets heated up, it expands and puts pressure on a diaphragm which opens and closes a switch that controls the gas to the burner. Just set the dial to what you need the temperature to be. Over time, it is possible for your thermostat to lose its calibration. Sometimes, the thermostat sensing bulb comes loose from the holder. If it is out of place, the thermostat may be getting faulty readings. If this is the problem, re-aligning the bulb properly will take care of this problem.
Digital display models use a sensor to control temperature. If this is faulty, replace it. Other ovens use a mechanical system to control the temperature.
On many models, you can adjust your oven thermostat using a small screwdriver. The adjusting screw is located on the thermostat valve stem. Remove the knob and you'll see the screw underneath it. You want to turn the oven on and run it through at least two cycles while watching a calibrating thermometer in the oven for high and low temperatures. Adjust the screw as necessary to fine tune the temperature.
Some models don't have an adjustable thermostat, and you will have to replace the thermostat if you want to resolve the problem.
Mar 28, 2015 • Ovens
2answers
My oven heating element does not heat, we heard a loud pop and it quit, model 79096112400 kenmore, where do i start checking
Hi Eddie. It sounds like a bad heating element. This is easily replaced and not too expensive at about $60 for a new heating element. First lets verify the heating element is bad. Follows these steps:
1. Find the 50 amp breaker to your oven in your electrical panel and turn the power off. Just to ensure your safety also unplug it from the wall (incase that pesky neighbor wants to see you break dance and decides to turn the breaker back on while you are working on the oven!)
2. Pull stove away from wall or out so that you can access the back panel.
3. Remove the back panel and look through the insulation on the lower 1/3rd of the oven to find the ends and connections to your heating element. There should be one wire on each side of it secured by a screw or slide on connector. At this time you only need to remove the wire on one side of the element. This is for testing and verification purposes.
4. After removing one end of the wire take a multimeter or any continuity tester and put one probe on each end of the heating element connection on the element itself. Right where the wire connects from the one side you removed, and you can place the other lead right on the connection/connector metal part of the element connector. If the heating element is bad as I suspect, you will see that there is an "Open Line" condition or zero continuity which means infinite ohms on an ohm meter. If the element is good you will have continuity and your meter will indicate 20-40 ohms. If you did not damage any electronic controls when the element blew, you will be good to go with a cheap element replacement. Otherwise you may have damaged electronic controls (control board) as well. Check out this link as it will have great information and Youtube videos to show you how to test and replace this element. Good Luck!
http://www.appliance411.com/faq/test-element.shtml
Regards,
Randy
Appliance411 FAQ Testing Range Stove Oven Cooktop Element
Dec 10, 2014 • Ovens
How do I check heating elements?
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
Kenmore electric oven will not bake
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
1helpful
Oven will start to heat up and then display will not work so cannot turn oven on. WIll turn back on by self about 20 min later
Oven comes on and off intermittently or heats very little:
If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem.
ALSO Test the Burner Heating Element The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Bosch HBN7052 - main fuse tripping even after replacing the heating element
It appears there is too much current (electricity) being drawn towards the element, seeing once you replaced it, it worked fine for 5 minutes and then tripped again...I believe the problems lies within the wiring going towards the element, or the thermostat that controls the amount of current coming towards the element. Instead of turning off at a desired temperature, its not and continuing to heat up to the point of tripping the fuse. Try replacing the thermostat.
Dec 01, 2013 • Bosch Ovens
2answers
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Frigidaire oven will not heat up
Not popping sound you heard was the element popping take care of it out did you take your fingers and go round the outside of the element you'll find a whole the place that element you get your heat back
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
