If i yell into the headset it hears my voice, but when wearing it and trying to talk to someone they can't hear me on it
SOURCE: Microphone does not work
you have to reset the head set by pressing the base button and the earpiece button toghether for about 10 sec and the system will be on factory settings.
SOURCE: When I am talking to someone on the phone i get a lot of static.
see what TTY mode your phone is in. TTY mode is under call settings or go to voice command and say TTY mode. I keep mine off. This mode is for people who are deaf, and people who are hard of hearing and use hearing aids.
SOURCE: cant hear my headset for ps3
On your ps3, go to accessory settings, then sound settings.
Make sure the output device is the same as the input device, ie. your headset.
Hope i helped :)
SOURCE: I have tried all configurations
You need to remember a couple of things when using amplifiers and
headsets. Normally they will not work if you connect them to a phone
with cordless accessories. Also, you need to make sure that you're
connecting the amplifier to the HANDSET jack on the phone (this requires
removing the handset off of the phone to access an open line). Give that a try and you
should be fine. If not, contact your retailer or Plantronics at 800-544-4660 x5538 for warranty service.
Good luck from Headsets Direct!
