Question about HP Pavilion A6000 Series,amd Athlon 64 X2 4400 2.30ghz,ram 3072mb,hdd 500gb
Hp pavilion a6000
Will not start up green light on the power supply is on, However not flashing, All compositors are good.....hellllllp
Posted by Jessie Swafford on
Daryl Buck
    Sergeant:
  • 294 Answers
Is anything happening when you turn the switch off and on again?
If not you may be hanging on the BIOS somewhere.
Been "fiddling" around?
Posted on Jan 27, 2014
Green power supply light is flashing so power is getting to the computer, however the computer will not start from start button. Have removed case and tried ***** start button. Didn't work. Comput
Power getting to the computer/Power Supply?
Yeah.
Power Supply good? -> NO
A) IF ALL of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use from 51 to 125 Watts of power.
Just depends on what Processor it is.
HP Pavilion a810n Desktop PC?
Uses an AMD Athlon 64 3300+ processor,
(Operates Up To a frequency rate of 2.4GHz)
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00280647
http://en.wikipedia.org/wiki/List_of_amd_athlon_64_microprocessors#.22Newcastle.22_.28CG.2C_130_nm.29
Can use up to 89 Watts of power.
Your Power Supply doesn't even have enough power to spin fans, much less start the Processor.
Want to test the Power Supply? Have a multimeter?
No? Have a power supply you can borrow for a test unit?
KNOWN to be good, and Compatible?
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 05, 2012 | HP Computers & Internet
Hi i have a sony PFM42X1 has vertical lines over entire screen, on turn on. has a horizontal line across the middle of the screen. the colour is mixed pink,yellow and green. you can see the ghosting of...
I seen 2 post with same problum diffrent explations, I have the same TV with the same problem. I am sorry that all the answers are so silly and basic. I just open up mine to check all the compositors to see if their are any Bulging or to see if anything looks damage. I will pull the Power supply and start checking the compositors. and let you know. I will look in other places first to see if I can get some REAL Answers. Poco Zocko Actor
Oct 02, 2010 | Sony PFM-42X1 Plasma TV
Green light is flashing in back of computer but it will not turn on
if the green light you're mentioning came from the power supply, you need to replace it. green light flashes from the LED at the back of the power supple serves as an indicator if you have a good or a faulty power supply.
Aug 07, 2010 | Compaq Presario 5000 PC Desktop
Acer al1713 monitor and the power led flashes form yellw to green
The short answer, replace all of the capacitors. They can be bad without swelling. And there may be one 47mf/16v off to itself, if it fails, monitor will not come on. Also, check the menu or mode setting to make sure your VGA/DVI agrees with the cable if the monitor has both.
Jan 01, 2010 | Acer AL1713 17" LCD Monitor
Power supply light keeps flashing green and problems with tray op
under normal conditios power supply light should be a steady green light not flashing if not power supply is might be bad call (800) 4MY-XBOX
Oct 11, 2009 | Microsoft Xbox 360 Console
Dell XPS400 No Start!!
If you fan isn't turning like it should, it is definitely a power supply issue. Go out and purchase a power supply with 250-300 watts...thats a good standard wattage!!
May 12, 2009 | Dell XPS 200 PC Desktop
SONY PSP WONT WORK.
try starting it without the game inside
Dec 02, 2008 | Sony PlayStation Portable (PSP) Console
Dell SX260...Wont Boot...Power Button Flashing Amber....grrrr!
Try these (un order of degree of difficulty) 1. Try replacing the battery on the system board. it is  typically a CR2032 button-style battery. This helps if the computer has been off for a long time.  2. Make sure all dust has been blown or vacuumed out of the computer. 3. Check to see if the USB pins are bent inside the connector on the back and the front of the computer. Straighten if possible. 4. Remove add-in cards, fans, shrouds, and heatsinks, then check the system board for leaky or mushroomed capacitors. If you would like, this may also be a good time to see if the processor is seated correctly or possibly short-circuited (burned black on the bottom, burnt or missing pins, etc). If it is any of these, you may need a new system board (motherboard) 5. It may be that you need a new power supply. Do your best to make sure that it will fit your computer case and have all the power connectors you need; they are not created equal.
May 05, 2008 | Computers & Internet
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
HP Pavilion A6000 Series,amd Athlon 64 X2 4400 2.30ghz,ram 3072mb,hdd 500gb Logo
106 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
