SOURCE: protection light
You cannot parallel two subs AND run them on the Bridge. You must have at LEAST a 4 ohm load on the bridge, and 2 4 ohm subs in parallel equals TWO OHMS. BAD!!! Move each sub to it's own channel or your amp will soon fry.
SOURCE: Sony XM-2200GTX...Power, Green Light, All OK, No Sound!
Sony generally drives their power light from a source that does not rely on the amplifier's switching power supply. This means that it's not a good indicator as to the health of the amplifier. As long as you have B+ and remote voltage, it will light up. Since you've tested the speaker and the signal source, I think the amplifier is likely defective.
SOURCE: amp and sub connection
Too many problems, lol. One at a time. I lost you in your post, run by me again but one amp at a time.
SOURCE: will a sony xm-1652z 1000w amp run 2 dvc 4 ohm 800
IT WILL POWER THE SUBS WITH NO PROBLEM. I WILL NEED TO KNOW WHAT THAT MAX WATT THE SPEAKERS CAN HANDLE BEFORE GIVING PROPER ADVISE. RMS IS RECOMMENDED MINIMUM SETTINGS.
SOURCE: AMP shuts off
your problem could be in the fact that you are trying to overdrive the amp. sony will not carry a 1 ohm stable load and if your speaker are 4 ohm speakers wired in series then you cant drive the bass your looking for. try using soundstream tarantula amp or new hifonics block mono class d amp with about 1000 watts rms. what kicker subs do you have? that will also make the difference in amp choice. im running tarantula on 4 polk momo 4 ohm 12's and has broke my back glass in my jeep twice one time was for a show. oh well let me know. happy boom boom. i'll be glad to help
