Televison & Video Logo
Ryan Hansen Posted on Jan 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TV going through channels continuously
Hi, I own a 32 inch LCD Westinghouse HDTV. Earlier I went to turn the volume up and the TV actually shocked me and then began to cycle up through the channels. I unplugged it, plugged it back in to find that the TV wouldn't turn on. I searched for the remote to try turning it on with that, but no luck. After waiting for a bit, I tried again a couple times and it worked. But then it simply cycled up continuously through the channels with no end. How do I stop this? Is it going to need serviced or replaced?
Steve
Level 3:
  • Westinghouse Master 3,290 Answers
  • Posted on Jan 27, 2014
Steve
Westinghouse Master
Level 3:
Answers
3290
Questions
Helped
1127007
Points
12184
Try a reset. Different models do it different ways - but most require either unplugging for 5 - 10 minutes and plugging back in - OR - press and hold the power button on the TV for 20 - 30 seconds. You may need to access the Set Up Menu and perform the RESET from within one of the menus. Good luck!
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jan 03, 2009
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
marionbagget
  • 718 Answers
  • Posted on Feb 11, 2009
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Anonymous
  • Posted on Dec 31, 2009
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Anonymous
  • Posted on Apr 15, 2010
SOURCE: westinghouse 32 inch screen goes blank
Westinghouse LTV-32w1
replace capacitor c162 on power supply
power supply was a delta electric dps210ep-2c rev01
reheat any solder joints that don't look 100% as well .
such as c310 .
this is a known working fix . try before you buy a supply .
cirocpatel
CIROC TECH SUPPORT
  • 524 Answers
  • Posted on May 11, 2010
SOURCE: got new tv Westinghouse LTV-32W1 32 Inch
in this case i have to know if your tuner is working fine or not. First of all i like you to connect any external player Exp. DVD or blue-ray player if that works with audio then it is inverter board. if audio doesn't work then its main board. Also you will find out that if dvd is working fine on your tv than your tv setting is wrong or the tunes is dead. either way if tuner is gone then you have to change the main board. Either way let me know what went wrong i can provide you more information about what part need and where can you get it from.
Please let me know if you have any further questions or concerns. Also rate me if you like this post.
Thanks.
How do i get cable tv on my westinghouse tv
Go to the menu look for the input settings make sure it is set for cable not air. There might be a input button on the side of tv or on remote that will let you select which input to use. It will have to be set on cable thin scan for channels.
1helpful
My westinghouse 32 inch flat panel tv turns on i get the picture then in about 20 seconds picture goes out but still have volume. i turn it off then on again and the same thing happens ....help
This tv have a dead long board call the LCD inverter board.This long LCD inverter board job are to help the LCD screen panel to have a backlight to produced a picture.Replaced this long LCD inverter board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Westinghouse 32 inch lcd hdtv model # VR3209DF. screen problems
Ur tv the Tuner board,that where the coalax broscast signal cable come in to this board.This board is starting to have problems.
3helpful
Ihave a 32 inch flat screen Westinghouse tv that comes on with picture for 8 seconds then goes blank. I still have sound....can you help?
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Westinghouse 32" lcd tv model # sk-19h210s won't turn on
Try unplugging it . Wait a few seconds and plug it in again.
1helpful
2answers
My 32 inch westinghouse lcd tv's screen turned pink when on
your T-con board is failing you need a tech to replace it about a 150 dollar job
6helpful
3answers
Unable to program cable channels on westinghouse lcd tv
There is some system reset to set the tv back to default settings. Also some boxes are picky and want the tv to be on chanel3 or 4 for the scan.
One channel only has no sound
can't focus the picture or tex on my new sanyo 32" lcd hdtv model dp32648
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
