Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Noisy Hoover hed6612 dishwasher
Hello, the other day a pipe came off from underneath the dishwasher during the wash cycle and the bottom flooded with water spilling onto the floor. I have put the pipe back on with a new hose clip however now there is a loud grinding noise only during the actual wash cycle and not during the fill up or emptying etc. Do you think a pump has been damaged or is it something else? Thanks Roger
Posted by rogerdevs on
ray_scheel
    New Friend:
Con you check to see if the insulation over the top and sides of the dishwasher was touching the floor and wicked up enough water to get wet? That would reduce the sound dampening characteristics. It is also possible that the hose being shaken off was caused by an issued with something jamming the pump; check the drain grates to see if there is anything you can pull out.
Posted on Jan 27, 2014
5 Related Answers
DENNIS MITCHELL
  • 1003 Answers
SOURCE: Frigidaire dishwasher
CHECK WATER INLET SOLENOID OR TIMER
Posted on Jan 18, 2008
Anonymous
  • 53 Answers
SOURCE: Dishwasher not pumping the water out?
hi
the larger motor housing underneath the unit is what moves the water around to wash, the smaller pump is the drain pump, if you don't hear that running it is likely in need of replacement. check your paper work for warranty, if it's out of warranty try to find a deal online and it's relatively easy to replace
Posted on Mar 21, 2008
Anonymous
  • 3 Answers
SOURCE: Water spilling out on kitchen floor
Sounds like a clogged drain line
Posted on Oct 29, 2008
Anonymous
  • 166 Answers
SOURCE: leaking dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Posted on Feb 11, 2009
bvbmvera
SOURCE: Noisy drain pump on FDB635RF?
Two questions: 1) Are there filters that need to be cleaned on a routine basis with the FDB635RF? and 2) What causes the scum left behind on glasses and utensils? I use a rinse aid, but doesn't seem to be helping. This is a recent problem.
Posted on Jul 22, 2010
Hoover DDY-062 dishwasher leaking from safety switch.
Sounds like you need a new safety switch or the installation of it is not good. Is the water level getting too high which would indivate that the system has another problem in letting in too much water.
Water flooding out of bottom of door during wash cycle. Door seal is good and nothing else is leaking. Thanks,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
4helpful
3answers
HOOVER HOD6615 DISHWASHER CONTINUAL BEEPING AFTER INITIAL RINSE & REFUSES TO PROCEED TO WASH CYCLE WHATS THE PROBLEM?
This could be a safety trigger due to bottom water leak. A anti flood device (polystireen float and micro switch) that switches washer in shut off mode and does not continue until the water leak (pipe or hose clamp) that causes the float to trigger the device. Check the bottom of the washer for traces of water and rectify any leak before the washer will continue.
1helpful
3answers
Have a hoover hed6612 dishwasher just over a year old, it pre rinses and part washes and then doesnt move to the next rinse cycle instead it stops and beeps continuously with the prerinse and wash buttons...
We have had the same problem but have found a fix.
1. If any of the wheels have come off the top sliding basket/rack you need to make sure they are all back on for each wash ( ours are very loose! )
2. Push the top rack in FIRMLY before you wash - make sure it engages at the back.
That's it - solved it for us after months of problems.
I think that as the wheels get worn the top rack does not fully engage at the back and this is when the problem starts manifesting itself. We have some new wheels on order but they are taking ages to arrive.
Hi, hoover hed6612-80 when the door is opened the
The problem is most likely that the drain is blocked. Remove the lower front panel on the dishwasher. You will see the drain hose connected to a small pump close to the floor. disconnect the hose and remove the pump. There will be some water so be prepared with some paper towels, or rags. Remove the small pump so you can visually inspect it on the inside, remove any debris you find. If there is no debris there go under the kitchen sink and disconnect the other end of the dishwasher hose. you can then remove the entire hose to inspect it for a blockage. If no blockage in the hose, you must then check the path of the drain water through the garbage disposal [if you have one] and then the trap.
Oct 01, 2009 • Dishwashers
Frigidaire Model FDB2810ldc0 s/n:TH43526319
Dishwasher is leaking water from underneath during the rinse cycle and a small drip during the wash cycle
Sep 22, 2008 • Dishwashers
Hotpoint Superplus 7822 dishwasher
At the beginning of the cycle the dishwasher is attempting to pump out any residue water in the waste pipe and sump. It could be that the motor is sticking but you would probably also suffer from it not draining properly.
It may just be noisy pump. I have a similar model and it is also quite noisy but nothing extraordinary.
When the dishwasher is pumping out at the end of the washing cycle it may be quieter when there is water in the pump/pipes but then gets noisy as it 'pumps air'.
Tablet door dosn't open during cycle
It sound like a detergent cup issue (the door doesn't open at time) A very simple test for it is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happen to the tablet. In case the tablet will be dissolved : - The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. - The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Good luck !
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
Top Frigidaire Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
