Question about VeriFone Omni VX-510 Credit Card Machine Stapler / Staples
VeriFone VX510 TCP error 1009 - VeriFone Omni VX-510 Credit Card Machine Stapler / Staples
Posted by Brandi Luczak on
Kelli Sims
    Scholar:
    New Friend:
  • 154 Answers
Your internet connection is not established check internet and Ethernet cables. may have to reboot your modem
Posted on Mar 06, 2015
2answers
Why is screen indicating download is needed?
PDF]Verifone VX510 User Guide - Moneris Solutions
www.monerisusa.com/support/~/media/Files/.../Vx510_qrg.ashx
VeriFone Vx510 with SoftPay. Quick Reference ... their PIN, and encourage them to protect their PIN. ERROR ... the terminal screen. ... PINpad display is blank: See "PIN Pad Error" ... the ALPHA key (repeatedly if necessary until the desired.
[PDF]Vx 520 - User Guide - Verifone Support Portal
Vx 510 tcp
no connected to internet, check all connections, reboot modem and terminal by unplugging power and Ethernet cables wait 1 min plug back in.
I need a VeriFone Vx510 to start with Dial Primary first.
Verifone programming is different between countries and even between versions. In New Zealand the setting for internet or dial comms is in UTILITY/COMM CHANNEL. It will have a setting for IP, or DIAL, or IP/DIAL if using both where it will try internet and then use the dial if the internet is down.
2helpful
2answers
What does TAMPER
"TAMPER" displays on Vx510, Vx610, or Vx670 terminal Problem/Task "TAMPER" shows on Vx510, Vx610, or Vx670 terminal Environment VeriFone Connect Any Verifone manufactured device that has the capability to contain it's own internal encryption (including Vx510, Vx610, or Vx670 terminal) Cause The message: "Tamper" will appear on the Vx510, Vx610, or Vx670 terminal if it is physically opened, damaged, or if it is jarred enough to flip and enable the internal tamper 'switch'. The reason for this is to ensure any sensitive data that passes through the terminal during a credit card transaction is not intercepted or compromised. Customer Solution/Action 1.
Contact repair facility for repair/replacement of the affected device
If you still needs help call us at (775)358-2922 ask for Randy http://freshpoint.org
2helpful
2answers
VeriFone VX510 "TCP Error 10030003" is the error
Tcp ip errors 1001 to 1009 are going to be communication errors regarding your isp equipment. The first thing you want to do is not just power cycle your terminal but also the router and modem or just the one if you have a combo equipment. Just like the commercials use to say when your online your router may just go down quietly. So after unplugging everything wait about 2 mins and plug back in the router/modem wait for the lights to become silent all except the online light which should flash. Then once those return plug in your credit card terminal and attempt a transaction as normal if your still getting the error more then likely its an issue with your internet processor and i would advise calling to see if there is maybe an outage
5helpful
4answers
How can we resolve bad rtc chip error in verifone vx510?
bad RTC can be repaired. the machine is equipped with multiple sensors inside. if one of them goes bad, or the Battery is dead tampering or bad RTC will show this can be fix by replacing the sensor and or the battery if you need this to be done call me @ (775) 358-2922 hope this help : - )
6helpful
2answers
I have two verifone vx510 cc machines. 1st) Need
My verifone vx510 display ***** security alarm ******* BAD RTC CHIP PLEASE REBOOT
I am using verifone vx510 ,When I insert a card it is show Connection failed. What should I you?
VeriFone Omni VX-510 Credit Card Machine Stapler / Staples Logo
Top VeriFone Office Equipment & Supplies Experts
Ekse
Willie Cooper
Willie Cooper
George Mclaughlin
Are you a VeriFone Office Equipment and Supply Expert? Answer questions, earn points and help others
