Question about Apple iPhone Smartphone
I dropped my iphone on the floor and the screen is cracked alot and the touch will not work but if i take off the screen will the touch work
Posted by Nadyah Ellen-nevaeh... on
andrewmoir93
    New Friend:
    Problem Solver:
  • 6 Answers
No it won't work, the front glass is the digitizer (touch screen) which allows you to carry out touch or swipe actions to operate the phone. This is fixed or bonded to the lcd which gives you the display. Depending on which model and how competent you are then they are an easy and cheap diy fix, if not then you will have to look for a local repairer.
Posted on Jan 27, 2014
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: dropped iphone
Did you trying going back to the Apple Store? It is still under the warranty.
Posted on Jan 08, 2008
Anonymous
SOURCE: iPhone touch screen not working
I have the same exact problem. I dropped mine, and it landed half on concrete, half on a piece of foam board, and when I got to shut mine off, it will slide to power off, but will not slide to do anything else. Everything works perfectly fine, people calling me, texting me, nothing is broken or cracked, I can't even unlock mine, it's stuck and it's making me very upset! I want an answer as to what I can do and or can't do.
Posted on Jan 28, 2009
Michael Taylor
  • 50 Answers
SOURCE: iphone face cracked
Here is an iPhone Repair Guide that shows how to open an iphone. a and replace the glass. Once it is open it's as easy as prying the old glass off the front assembly and installing a new one, the parts are available on ebay.
Posted on Apr 22, 2009
Anonymous
  • 8 Answers
SOURCE: iphone touch screen problem
Try pushing the power button and the home button at once and wait for it to restart, that should fixed the problem...
Posted on Aug 03, 2009
Anonymous
  • 630 Answers
SOURCE: My touch screen won't work after I've dropped it.
Probably damaged or loosened an internal connection. Similar thing happened to me and I needed a new motherboard.
Posted on Sep 19, 2009
I dropped it and although the screen isn't physically broken, it's not working properly.
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - Is your Android Touch Screen not working or being unresponsive? ...This will wipe your phone/tablet and return it to its original condition. ... a replacement for a glass broken? will I not reboot my phone and then it will work? .... My zenfone5 was dropped into water and some part of the screen isn't working.
iPhone Screen Not Responding - how to fix? - Tech-addict
www.the-tech-addict.com/iphone-touch-screen-not-working/
Nov 22, 2015 - Although the touch screen problem doesn't occur that easy, but still one can come ... Steps to fix if your iPhone Touch Screen not working properly ... to perform a factory reset i.e. restore your iPhone to its original factory settings. ... Touchscreen devices like iPhone, iPad, Tablets etc. are not only quite costly ...
Dropped phone, screen doesn't work. What repair kit do I need ...
forums.androidcentral.com > ... > Samsung Galaxy S3 > Sprint Galaxy S3
Sep 11, 2013 - When I try the unlock pattern on teh touch screen it does not work. ...the glass there does appear to be a spot that isn't the glass that is physically broken.... And I'm pretty sure once you get the phone disassembled, its just plug and ....Although I only had to do 1/3 of what was in them, they really are great for ...
How do I get my pictures off my phone if I have a broke screen ...
Mar 10, 2014
Brand new Galaxy S4 "broken" for no reason.
Aug 12, 2013
Does the digitizer break when screen is cracked on the Nexus 7 ...
Aug 3, 2013
TF700T now won't turn on.
Oct 15, 2012
More results from forums.androidcentral.com
Feb 03, 2016 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
Daughter dropped her iphone 5c on the floor. Every thing works but the touch screen won't work. What can we do??
Replace the screen. Check out YouTube.com and search for iPhone 5c screen replacement if you want to try it yourself.
Mar 10, 2015 | Apple iPhone Cell Phones
I dropped my iphone 3g and cracked the screen....I replaced the screen and now the bottom half won't work...it says slide to unlock...and it won't slide...but the top that says slide to turn off...
Check the 2 pins connected on the home button if touch the interface of the board,might not hitting that is why the slide unlock not working.
Jul 21, 2011 | Apple iPhone Smartphone
I dropped my model No. A1241 phone and the touch screen doesn't work but it has no cracks. how can I fix it?
not having a crack on the screen doesnt mean your touchscreen will work. you said you drop your phone, it has a great possibility that it cause an internal damage to some of the microchip inside your phone that controls the sensors of your touchscreen.need to reheat the microchip inside it. open your phone and try to check for the microchip near the flex from the board of your phone going to your screen. then reheat it, but dont move it.
Jul 10, 2011 | Skque SILICONE SKIN CASE FOR APPLE iPHONE...
I dropped my iphone on the floor and there is sound coming from it but the screen is completely black, Will i have to buy a new screen?
Hi!
If your screen is not having a crack on it then there is a possibility that it can work again.
But if it has a crack then you need to buy a new screen.
Hope it helps..
Thank you for reaching Fixya.
Please leave comments for further assistance.
Apr 06, 2010 | Apple iPhone 3G Black Smartphone
My iphone fell down,afterthat i could not operate touchpanel,but i can switch of using slide key of the touchpanel,what will be the problem ?please help
the problem might be there might have been loose connections after the drop or the touch panel might have been damaged, have it repaired by an expert technician
Feb 16, 2010 | Apple iPhone Smartphone
IPhone touch screen not working
Jan 28, 2009 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
65 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
