Cars & Trucks Logo
Posted on Jan 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 02 pontiac montana with factory dvd and overhead monitor. is it possible to replace factory stereo with aftermarket dash cd/dvd player and have it play through overhead monitor and aftermarket screen?
RJ motortech auto repair
Level 2:
Habit-Forming:
New Friend:
  • Expert 75 Answers
  • Posted on Jan 27, 2014
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
75
Questions
0
Helped
20940
Points
172
Yes,u can get it done for sure.u might need wiring kit to joint the system together.make sure u can get the kit before to buy aftermarket system.
  • doce1seven Jan 28, 2014
    I was given the system (barter) jensen phase linear uv8. Can't find a/v wire diagram for pontiac montana anywhere!
5 Related Answers
Anonymous
  • 1990 Answers
  • Posted on Jan 22, 2009
SOURCE: 02 GMC Sierra Denali Aftermarket Stereo Installation
The only way to get this is from a Salvaged Truck. I Still have my cd Player in My 95' Silverado because I could not find one Either. I went ahead and Installed the Aftermarket System and just unhooked it.
Anonymous
  • 170 Answers
  • Posted on Mar 17, 2009
SOURCE: Factory cd player doesn't play aftermarket burned cd's
What format are you burning them in? CDA or MP3 most Factory units will only play CDA format, just pick you up a copy of Nero and choose Aduio CD, it will convert you MP3 format to CDA and you should be able to playthem with no issue, the CDA format also works in the old portable CD players as well...
Hope this Helps,
David
If my solution was helpful please rate accordingly.
kebomachy
  • 22 Answers
  • Posted on Mar 27, 2009
SOURCE: Radio/cd player not working in 1999 pontiac montana
did you pull the radio out? it might just be a loose wire or something simple.. the car is 10 years old stuff becomes loose
Anonymous
  • 21 Answers
  • Posted on Apr 20, 2009
SOURCE: i want to install a
Under the steering wheel by your feet, remove the 2 screws that hold the panel up. Carefully remove that, then just take your hands and start popping the dash off, but be CAREFUL!
kurtmorganec
  • 55 Answers
  • Posted on Sep 27, 2009
SOURCE: Is it possible to install a aftermarket dvd player
yes it is poss just be prepaired to rub some wires
1helpful
I have an '02 Buick Rendezvous that doesn't have a overhead DVD player installed in it. Was wondering if I could get a factory one from an Uplander, Terraza, or Montana and install it in my Rendezvous
Jonathan,
You are trying to do something that may cost more than its worth!! Just take it to the local stereo shop and tell them what you want... if they are good.. they can do it!
1helpful
My 2004 Lincoln Navigator has a DVD player near the passenger side but It doesn't have a monitor. What is the DVD player for.?
Is the DVD slot in the dash board or in the second row? Does it appear to be factory installed or possibly aftermarket? If factory and in the front, I'd suspect it's for loading navigation system updates. Does your Navigator have factory navigation?
-Rod
My dvd player for movies is not working has no power
Possible problems with DVD player after replacing Cabin Air Filter ...
www.topix.com > Pontiac Montana
Apr 13, 2011 - 2006 Montana. Posted in the Pontiac Montana Forum. Leave a Comment ... I recently had my cabin air filter replaced by Jiffy Lube. After they had ... If not, could the dvd player simply blown a fuse and just needs replacing? It just seems ... 14 Famous Movie One-Liners You've Been Quoting Wrong For Years. DVD Repair
Jan 18, 2010
Replace VCR with DVD player in 2001 Montana
Feb 2, 2009
Chevy Uplander "CD Mech Error"
Aug 29, 2008
Reports: 2004-2006 Chevy Uplander Sliding Door Problems ...
Aug 21, 2007
More results from www.topix.com
Pontiac montana sv6 dvd player removal - YouTube
? 1:18
https://www.youtube.com/watch?v=21TTD0ayThc
Oct 15, 2015 - Uploaded by Joshua Freeman
I recently got this 2005 montana sv6 from my grandoa and thedvd player was jamming up and not working ...Missing: movies
How do I fix the clock display on my 1999 Pontiac Sunfire?
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Link to oem stereo removal procedures.
Pontiac Sunfire Radio Repair and Removal 2000 2005
Link to aftermarket stereo install / connect procedures. ( Sunfire Video )
HOW TO INSTALL AFTERMARKET STEREO PONTIAC SUNFIRE
Link to aftermarket stereo install / connect procedures. ( General Video )
How To Install Car Stereo Single Double DIN Car Audio 101
Have a nice day.
The aftermarket dvd player screen in my 2008 dodge grand caravan went out and I need to know how to take it out. Can anyone tell me how to take the compartment off of the overhead console?
If you're not familiar with removing parts inside a car then you probably shouldn't try it. Maybe go to a radio installer and see if they can give you some tips. It sounds like you're going to have to go to someplace to have it fixed or replaced anyhow.
How do you take of the dash paneling to install a new aftermarket cd player?
  • Disconnect the negative battery cable from the Jeep Cherokee battery with the 10 mm wrench.
  • 2 Remove the five screws on the top edge of the dash panel with a Phillips-head screwdriver.
  • 3 Pry the trim panels surrounding the climate control knobs away from the dashboard with the trim panel removal tool.
  • 4 Remove the trim panel that surrounds the headlamp switches (located to the left of the steering column) with a trim panel removal tool.
  • 5 Remove the two screws behind the trim panel that surrounds the headlamp controls with a Phillips-head screwdriver.
  • 6 Pull the dash panel that surrounds the stereo and covers the instrument panel of the Cherokee, away from the dashboard by hand.
  • 7 Remove the two screws from the stereo mounting bracket. One screw is on the bottom left corner, the other screw is on the top right corner. Each screw can be removed with the 10 mm socket and drive.
  • 8 Pull the factory stereo from the stereo mounting dock.
  • 9 Disconnect the stereo wiring from the back of the factory unit.
  • 10 Connect the Jeep Cherokee factory stereo wiring to a wiring harness adapter. Connect the wiring harness adapter leads to an aftermarket stereo. Slide the aftermarket stereo into the stereo mounting bracket and replaced two screws at the opposite corners with the 10 mm socket and drive.
  • 11 Replace dash panel that stretches across the top of the steering column.
  • 12 Replace the two screws at the top of the headlamp control switch. Replace the trim panel around the headlamp switch.
  • 13 Replace the trim panel that surrounds the climate control knobs.
  • 14 Replace the five screws on the top edge of the dashboard with a Phillips-head screwdriver.
  • 15 Replace the negative battery cable over the negative battery terminal and tighten the cable to the negative lead post with the 10 mm wrench
  • 2helpful
    Need repair manual for 1999 Pontiac Montana
    I would recommend the MITCHELL'S Online Manuals. Go to www.mitchell.1.com and you can get a single subscription for about $10. When I had my own repiar shop I had te complete set of Mitchell's. Very complete and just a good as the factory repair manuals (maybe better). I especially liked the wiring diagrams. Very complete.
    Good Luck. . . . . BTW, you SHOULD replace the head bolts regardless of which type of gasket you use. Once they are torqued, they shouldn't be used again.
    2answers
    I have a 2003 GMC Sierra 1500 and it has a factory CD/Radio Bose system. The radio works fine but can't get the CD player to work, it won't eject or load a CD. I recently had an ignition fusible link prob...
    you might have to take it to the dealership to have the radio reprogramed. it should only cost 40 bucks. these radios are very tempermental and have a mind of their own sometimes. My profesional recomendation would be to have an aftermarket cd player in. they are much nicer and have way better quality than the factory radio's
    Top Cars & Trucks Experts
    ZJ Limited
    ZJ Limited
    john h
    Arnie Burke
    Arnie Burke
    Are you a Car and Truck Expert? Answer questions, earn points and help others
