I have the wet and dry braun epilator, 6 months old. It randomly switched on its light and started working even at the off button. It won't switch off. What to do?
SOURCE: braun 7526 shaver switch
Managed to fix it - actually was a 7680. Only do this if you:
1. have a small screwdriver set
2. are handy putting little delicate plastic pieces and springs together again
3. are prepared to face the possibility that you might break the shaver entirely
4. you are out of warranty so you don't care if you invalidate it
THE PROBLEM is caused by a small flat metal assembly that acts as a spring to hold the blue button in place. That is held by 4 small glue posts. The glue breaks down, the flat spring falls out of place and the blue button is no long in the right place.
TO OPEN UP THE SHAVER
a. gently remove the plastic cover around the electrical socket underneath, using a small flathead screwdriver to pry it open
b. the two metallic sides of the shaver can be pulled away starting at the bottom of the shaver
c. uncrew the four screws on the underside of the shaver
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd display
e. pull the spring and little plastic latch off the underside of the switch, make sure you remember how to put it back (took me almost 20 mins to figure out how to get that back afterwards)
f. slide the switch all the way up and pull it off the slide - you might need a little gentle force and a flathead screwdriver to coax it off - be careful you don't break anything here
g. remove the trimmer from the rest of the switch
h. put the blue piece back in place (mine had fallen out), then glue the flat metal spring back in place. I smeared brush-on crazy glue on the flat surfaces to hold it in place, I would imagine a four drops of reasonably strong glue on each of the glue posts would work best. Wait for the glue to dry and achieve strength.
i. slide the trimmer back into place, then the plastic latch and spring - this is the tricky part. Make sure the switch can slide on/off in all positions properly.
j. put the display/battery & cutter block back in place. put the back of the shaver on, hold the shaver together with your fingers and test the switch works in all positions without jamming. If so put the four screws back, followed by the metallic sides followed by the plastic cover of the electrical socket.
GOOD LUCK!!
Posted on Jan 28, 2008
SOURCE: Braun 5441: the on / off switch will not move to
there is likely a broken piece of plastis broken off on the back side of the switch and that loose piece is lodged in such a way as to not allow you to put the switch fully in the off position
to take it apart, you will need to remove the two screw covers at the bottom of the shaver...one on each side of the AC port. remove screws undeneath to seperate fron and back. examine the backside of the switch for a loose piece.
once removed, the switch should work fine but it my move more freey than when it was new. this is because the broken piece you removed was a part that clicks and holds the switch into the on or off position
Posted on Jan 16, 2010
SOURCE: shaver suddenly stopped working
I had the same problem with mine right after the two year warranty expired.
BUT I FIXED IT!!!
The problem seems to be bad engineering. Apparently the cleaning solution works its way into the circuit board of the shaver.
I took the razor apart (you need very small phillips screwdrivers), there are six screws. First remove the foils, then the blades (just pull them up). Two screws are where the head rotates. after removing the head, there are two more screws underneath the head. There are two more screws on the bottom under plastic caps beside the charging terminal. You can now gently slide the razor's hardware out of the case by pulling up on the head mounting arms while holding the case as you normally would shaving. (This sounds confusing but should be obvious as you do it.)
Looking at the circuit board i noticed some white residue on the board. I gently cleaned the board with small amount of alcohol and q-tips, being careful not to catch any cotton on the components of the board. At this point you can at least confirm that the motor is not burnt out and the batteries are charged by placing a flathead screwdriver between the positive terminal of the battery and the motor. It should come on if the motor and batteries are okay.
Next you hit the reset button at the bottom-front, then see if it comes on using the on/off button. You can do this step with the razor disassembled or assembled.
Hopefully this works for you. Now if only i could figure out a way to clean and refill the cartridges instead of paying $5 for 5 cents worth of cleaning fluid.
Posted on Jan 24, 2010
SOURCE: Braun Series 7 760cc dead after 2 months
Had this same problem with mine. One month after warranty was done with. I ended up opening the thing up and pulled the monster battery out of its socket and put it back in. Worked fine after that. One week and still strong. Another thing I did was to carefully bend up the flat pieces of copper around the battery to make sure they were still getting a good contact with the pins on the cover. Hope this works for you....
Also... I am not responsible for any damages that may occur.
Posted on Feb 02, 2010
SOURCE: Braun 7570 shaver won't switch off!
Most likely, the switch mechanism is broken inside and will need to be replaced. This part comes with the outer housing of the shaver and is available at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-syncro-body-housing-select-models-p-811.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Posted on Jun 29, 2010
