Shift Interlock System
The shift interlock system prevents a shift out of PARK unless the brake pedal is depressed. The shift interlock system has a shift lock actuator mounted on the floor shifter assembly. If the ignition switch is in the RUN position, the shift actuator will allow the shifter to be moved out of PARK only when the brake pedal is pressed.
Electroniclly controlled !
Condition
Possible Sources
Action
- The shift interlock system does not release or lock correctly
- Fuse in battery junction box (BJB)
- Brake pedal position (BPP) switch
- CHECK the BPP switch. REFER to Section 206-09 .
- Floor shifter wiring and/or connectors
- Transmission selector lever
- Ignition system
