Question about aFe 2005 BMW 7-Series - 745i, 4.4L V8 - Silver Bullet Throttle Body Spacers
Adjusting the AC belt - aFe 2005 BMW 7-Series - 745i, 4.4L V8 - Silver Bullet Throttle Body Spacers
How do you stop a belt from squealing when you crank the engine? It has a new belt less than 50k and self-adjusting tensioner. I was told not to spray anything on it...
50k isn't new but also isn't that high a milage , how old is the belt ,as age as well as mileage are the factors when replacing belts , chalk dust or french chalk , which are the same thing , thrown onto the belt just as starting should stop the squeal , the squeal is caused by the inner side of belt that runs around the pulleys becomes shiney and cant grip as well as it used to
Jul 27, 2015 | 2004 Toyota Highlander
Ac
There should be an idler pulley that keeps the belt tight, you loosen the center bolt in the pulley then turn down the adjusting bolt.
May 06, 2013 | 1994 Dodge Intrepid
Ac belt diagram
If you have the V6 engine, the ac belt has an adjusting pulley that you loosen to remove and install the belt. There is a bolt in the center of the pulley and an adjusting bolt above.
May 02, 2013 | 1992 Chrysler Lebaron
Need to change alternator belt 2003 kia spectra
1. Remove AC and P'S drive belt, if equipped.
2. Loosen generator mounting bolt and adjusting bolt.
3. Remove generator belt.
4. Install new generator belt and adjust to specification.
5. Tighten all bolts to specified torque.
Tightening torque mounting bolt: 27-38 Lb-ft (37- 52 N.m. 3.8 -5.3 kg-m)
Adjusting bolt: 14 - 18 Lb-ft (19 -26 N.m. 1.9 -2.6 kg-m)
6. Install AC and P'S drive belt, if equipped. and adjust to specification.
Nov 28, 2011 | 2003 Kia Spectra
How do you replace an alternator belt in a 2001 kia sephia
Welcome to FIxYa.com
Replacement
1. Remove AC and P'S drive belt, it equipped.
Thank you for using FixYa.com
Regards, Lee Davidian
Dec 21, 2010 | 2001 Kia Sephia
How do i change alternator belt 2003 kia spectra
Replacement
Dec 20, 2010 | 2003 Kia Spectra
How do you tighten ac compr belt on mit montero sport xls 3.5?
on the engine between the a/c compressor and crank pulley is adjusting pulley its above both of them in the middle loosen the 14mm nut on front of the pulley and turn the 12mm adjusting bolt clockwise until the belt is tight but not too tight if it continues to squeal just replace the belt you do not have to take any other belts off to replace
Jun 12, 2010 | 2002 Mitsubishi Montero Sport
How do you remove/replace the AC belt? There are a lot how to's for serpentine replacement but none that tell you how to remove the AC belt which has to come off first.
loosen the center bolt of the a/c idle pulley, then on top of pulley you will see the adjusting bolt, turn to loosen to remove belt, after new belt , tighten to where you have 1/2 play on elt then tighten center nut of pulley
Feb 04, 2010 | 2000 Dodge Caravan
Serpentine belt tensioner pulley adjustment
If this is an ac car you will need to get the correct belt and retreive a routing diagram from autzone or the manual. sometimes the pulleys are different for ac versus non ac and you may have to remove an idler to run the belt
May 23, 2009 | 1994 Pontiac Grand Am
Replace belt on 2001 toyota echo
that belt is wrapped around the alternator which is located on the passenger side of the engine compartment. loosen the alternator to remove belt. Wrap belt around pulleys and pull the belt tight but adjusting the alternator.
Jan 10, 2009 | 2001 Toyota Echo
aFe 2005 BMW 7-Series - 745i, 4.4L V8 - Silver Bullet Throttle Body Spacers Logo
724 people viewed this question
Top aFe Renewable Energy Experts
Ned Halaweh
Ned Halaweh
Vernon Taylor
Howie Snyder
Howie Snyder
Are you an aFe Renewable Energy Expert? Answer questions, earn points and help others
