Problem? And solution? Im not in possession of the users guide
SOURCE: camera error # e45
If it is under warranty i advice you give it for service as this is a pretty complicated procedure to get it fixed.
This error is caused due to the failure of lens alignment system.Try following the procedure below..
it may be the lens contacts or grit in the gears
open it up on
the side of the lens you will see a row of thin gold coloured contacts
that report the lens position back to the cpu sometimes these get dirty
or bent.on the side of the lens is a motor, look where the gear
meets the lens and use a pin to flip out any grit that is stuck in the
teeth.
Its very unlikely the lens is "out of alignment" this just
cant happen unless its been dropped or bashed, in which case it may be
broken.
Also i have heard some people bashing the camera a couple of times to get it working..
hold the camera and bash the edge next to the lens against the palm of
you hand as hard as you can, one I did have to get a little more
medieval on and bashed aginst a bit of carpet on the bench.. but it
worked... might be worth a go if the next step is the bin...
SOURCE: my camerais say error #e45
if you get this error message and it's telling you to see the user's guide - the user's guide will actually just tell you to do powercycle
with several powercycle (removing batt> putting it back in after 10 seconds> turn cam to auto) it may work again
if not, it needs repair
the user's guide doesn't have this defintion as it's an engineer code, only the repair center can determine or resolve
SOURCE: Kodak Error B03
Either your PCB board is damaged, your batteries are old, or your AC adapter is providing higher voltage than the required 3 volts.
SOURCE: i have kodak ls443 get error message camera error
Hello
Firstly, at the link below you can download a updated softcopy of the manual for free.
http://www.retrevo.com/s/Kodak-LS443-Digital-Cameras-review-manual/id/200dj378/t/1-2/
As for the error code you are getting, "error 45" is a lens related problem of LS443.
If the lens is not stuck, you may try to download the firmware from the Kodak site and update the one in your camera.
As the lens is already stuck, there is no choice except to send the camera back to Kodak for servicing.
Hope this can steer you in the right direction.
Kind regards
Andrea
SOURCE: cam sayes camera error#e45 see user's guide what
Solution for me: Strike the camera a few times. Error gone.
Seriously - I got this error on a very humid day. The error seems related to the lens moving mechanism. My V570 is 4 years old, not really worth the expense to fix. So .. a couple of hard smacks, and ... back to life.
