KitchenAid KSSP48QMS Side by Side Refrigerator Logo
Question about KitchenAid KSSP48QMS Side by Side Refrigerator
Adjust door for KSSP48QMS00
Door rubs against side panel
Posted by Mark Cira on
1 Related Answer
Anonymous
  • 481 Answers
SOURCE: freezer door rubbing
take the freezer door off and put a washer or two on the bottom hinge. sometimes there are extra plastic washers on the top hinge that you can move to the bottom to lift it up.
also check if the hinge is bent or loose, as this may cause the problem.
Posted on Jun 28, 2008
French door makes high pitched squeal when I open it
Lube will not help. The door needs adjustment. Look on top of the door where hinges are and try minor adjustment. You will need help to guide you.
How to repaie noise door
A noisy door can be of two different types. 1) is caused by hinges (2 or 3) Just put a few drops between hinge's segments and wipe off. Since you don't know which hinge is faulty oil them all.
2 ) is caused by door rubbing against floor or door frame. This requires the door to be removed and side rubbing (showing wear)
Jun 23, 2012 • Dishwashers
2helpful
Fridge door squeaks, freezer door bumps
Slacken the three screws, align the door and tighten the screws up again. Try not to lean on the door when it's open.
Driver door rubs against fender, will not allow door to open and close properly . Its wear the skirt of the driver door exterior. Truck is a 2007 ss silverado
sounds like one of the door hinges may need to be adjusted or worn enough to either re-align the door or replace a hinge pin providing the fender hasn`t been hit or become mis-adjusted.
Automatic side door wont work automatic
Check the electrical spring connectors at the door, and the contacts at the door pillar. They are notorious for corrosion. Take some steel wool or very fine sand paper, rub against the contact areas until a copper color returns. The pillar contacts get corrosion and very poor continuity thru the connector. The spring contacts in the door can also get corrosion on the back side at the connector, try cleaning them on the outside first before attempting to remove door panel.
1helpful
Garage door has a dirty grease mark down middle of door as if chain or something is rubbing on it.as it opens. When I watch it opens it appears that nothing is even coming close to door as it opens and...
When the door is opening the chain on one side of the rail is pulled tight and the opposite side sags. It is just the opposite when the door is closing. It could be the sagging side is rubbing against the door but it seems you would have seen this. Also the chain shouldn't have grease on it. Just a light coat of lubricant from the factory. You might try tightening the chain just a tad.
When shutting the door, it rubs against the side. The other side has plenty of clearance. How do I adjust the door?
If it rubs against the cabinet that its under there should be two clips that are attached to the top of the washer and is screwed to the underneath of the counter top. Take the screws out of clips and counter top and you should be able to move it enogh to fix the probels.
2helpful
Model TFA27R doors out of alignment; top of refrigerator door must be moved to right as it rubs against freezer door at top. How do I adjust doors?
Slotted screw on top of door, under a cover, needs to be loosened, adjust the door, tighten. That's it.
Driver door is all messed up
The hinge is possibly sprung where it attaches to the body. If it is welded to the body, a body shop will have to fix it. Sometimes you can shim behind the hinge if it is bolted to the body, but, usually not successful.
I have a Kenmore model 665.68611891 micro. The door pops open
Per se there is no real adjustment, but the linkage that holds the two nylon hooks on the door in may need to be lubricated with some lithium grease made for nylon or neoprene parts. The sliding neoprene part that holds the hooks in place is not sliding all the way down into position. That part once you take the cover off is right up against the right front hand side of your microwave exactly inline with the two hooks and next to the control panel assembly. Take the cover off and manually opening and closing the door you will see how that part moves up and down to release and secure the door in place. You will be able to see where to apply the lubricant which should be anywhere two or more nylon or neoprene parts rub against one another. Let me know how it goes or if you need more guidance.
Top KitchenAid Refrigerators Experts
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
