Footage was filmed with a different camera in SD
SOURCE: Importing Video to a Mac
XL2s are notorious for issues in interacting with final cut.
Simply put, sometimes it will work, sometimes it won't. But - there's a way around it.
Change the capture settings preset to 'non-controllable device'. Use the shuttle controls on top the handle of the XL2 to play back the footage as you wish. when you want to capture, click 'Capture Now' - It should do the trick.
SOURCE: Canon MV890 not being detected
uninstall and reboot if xp sees it then reinstall software and drivers
SOURCE: Canon XL2 wont record or playback tapes - grey lines.
The video heads may be clogged. Depending on the severity of clogging, if minor, you can clean the heads with the head cleaning tape other option would be manual and direct cleaning by technician. First, open the tape loading area for dust removal by canned air, clean pinch roller with Q-Tip using denatured alchohol and try it. If it did not do the job. Assigne it to a technician for about $99 for a professional cleaning. Good luck -James. For further assistance by email, go to www.camerarepairjapan.com
SOURCE: canon xl2 dont stars
Before you send GL2 camcorder to any service facility, make sure to call Canon. Here is the link to Canon service for XL2 -James
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=227&modelid=10350
SOURCE: my pc doesn't reckognize the canon xl2 when connected by firewire
Well, I hate that when it happens so we changed test-bed computer to Mac. The software runs as soon as two hardware, pc and XL2 is connected physically. I do not have knowledge on prem pro 1.5. but from technician's point of view, if both machines I/O hardwares are ok rest of the reponsibility depending on the program. This is how I would do it. 1. Restart the computer 2. open only the related program and have it ready for connect. 3. turn on XL2 on VCR mode, test make sure it plays few second. 4. connect the firewire. Hope this works otherwise, I will re-install the program and try. Beyond that point, it's good to consult with a local technician for diagnostic of your XL2 first. -James
