Recover your Chromebook
i personally don't know what's causing the problem
SOURCE: notebook wont boot up
That is typically an internal power supply issue. Power surges (Lightning) cause this type of behavior and a new motherboard is the only remedy. There are companies that specialize in repairing laptop motherboards. For the cost of repair you can probably buy a new one.
SOURCE: MY ACER 5610Z LAPTOP STARTS UP BUT WONT LOAD WINDOWS
WIth the limited fault description its a guess at best. you probably have a corrupted driver or hard disk fault. If you can try a replacement hard drive and reload OS you should get progress.
SOURCE: windows will not load up white acer screen comes
Use the windows CD if you have it.
Start the computer and enter the BIOS menu. Change the 'boot priority' or 'boot order so that the CD drive is before the HDD. Save your settings and restart the computer.
Enter the windows CD and press a key when prompted to load from the CD. Windows has a series of utilities that may (or may not) assist you in sorting the various error messages that appear on your computer when booting.
I hope this solves your problem : - )
SOURCE: Aspire 5349 Windows 7
Sounds like you have a corrupted OS. Did this machine come with windows 7? Did you do a system restore/recovery? Did you format the HDD before the retry? The DVD's you are using, did they come from a shop? ISO downloads? Where? If the restore/recovery fails. I would suggest to start from the beginning and do a Full Installation with a Known Good Win 7 DVD. Format the HDD in the installation.
