On the printer screen, there are 3 pages that cycle through indicating to clear jams from 3 different locations. When I touch OK for each of these, sometimes the printer will try to print the same document again and it will go another inch before stopping. If I do this enough times sometimes it eventually prints the document.
SOURCE: paper doesn't advance through the printer
Hi, Sounds very much like the feed rollers are worn out. If you can get to them without too much trouble you can clean them up with regular rubbing alcohol and a rag which will help the paper feed. You might also want to try unpluging the printer and trying to roll the paper feed buttons by hand and seeing if a piece of paper will feed through without catching anywhere. If it does catch somewhere, then you may very well have a small piece of paper jammed in the paper path causing the jam. Good luck.
SOURCE: Lexmark E238 prints about two thirds of a page and stops
Please follow the instruction given in this link:
clear the paper jam as given in this link:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=37:1:0:512:0:0&framed=&docid=ENUS25568&relevance=1
SOURCE: printer says clear paper jam. There is no paper jam.
Normal
0
I suggest you get a sheet of Card Stock (Heavy
paper) and place it in the feed way. Then press the print
button applying a slight amount of pressure on the Card Stock so it
will feed through the printer. The reason for this is in some cases I
have been able to clear the paper track of debris that was deposited there
over time.
Worth a try, as I have fixed a number of printers this
way, saving costly repairs.
Hope this helps.
Bud
SOURCE: When a page prints it only goes half ways and then stops and the printer says paper jam
Typically what I have seen with these printers if they do that it is
because there is something blocking the path of the paper. What you can
do if you are comfortable!!
Unplug the printer and
lift the printer and and give it a good shake and what ever is blocking
the paper will fall out if not it may loosen it enough so that when put
the printer down and take a flash light and shine it down the paper
feed area you will be able to see what is there and then pull it out
with either a pair of needle noose pliers or your hands.
Also if you have a warranty on the printer you can just call Lexmark
and they will either walk you through the same process or they will
send you a new printer.
SOURCE: paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
[email protected]
hope fore replay.... :)
