Question about RCA D52W23 52" HDTV CRT TV
SOURCE: d52w23 converence board
You can get one at the following Link.
http://servicemanuals.vstore.ca/
Posted on Jul 22, 2008
SOURCE: RCA d52w23 shows pictures in triplicate:blue green and red.
There are several things that can cause this. There is a "light pipe" that connects from the lamp to the color wheel. If the mirrors inside have become dirty, broken, or have shifted it will cause the picture to do this. Also the color wheel itslef could be dirty or worn out. And the final culprit could be the light engine itself. You can have any in home TV tech test these out for you.
Posted on Jan 10, 2009
SOURCE: rca d52w23 has distorted picture. it is shaped
Go to menu then setup look for convergence if not on menu you have a blowed fuse FL231 will be next to FBT flyback transfomer on right side there is 3 in a roll small brown looking caps but they are fuses it will be the one in the middle.You can take a pair of plyers to pull off top they are all removeable and just snap back on.
Posted on Sep 16, 2009
SOURCE: My RCA D52W23 has 3 colors split.
Thats a convergence failure. You can get a repair kit called " The ITC222 and ITC222A convergence option missing repair kit" From www.tvrepairworld.com which should solve the issue. The kit also contains the CD with instructions.
Posted on Apr 02, 2010
