Question about Lands Phones
UNLOCK SAGEM MY W-8
Null
Posted by GAGANSAINI on
  • 10 more comments
  • Bangla Nov 08, 2007
    Hi
    I have a Sagem my W-8 and I cannot use it, because it is lock.
    Would you please help me with unlock code.
    best regards
    Bangla
    [email protected]
  • Anonymous Dec 07, 2007
    how can i unlock my sagem my W-8 plz. give me some code and send to my email [email protected]
    much more thankz...
  • Anonymous May 28, 2008
    dear
    please help me to unlock my mobile phone.Its brand sagem my w-8
    regards
    Gayan
    sri lanka
    plz sen me unlocking code
  • edq6225 Jun 18, 2008
    I have the same problem like the others who posted their problems...UNLOCKING SAGEM My W-8 cellphone by VODAFONE
  • Anonymous Jul 16, 2008
    Hi
    best regards
    imei: 356794000384212
  • livingghost Aug 02, 2008
    sagem my w-8 and my imei number is 356794000886745
  • kristjani Mar 26, 2009
    i have e problem with my sagem my W-8 with imei : 356794000145662 i appresciate your solution or help.thank you by Cristjan.have a nice day with FIXYA.you are the best
  • comicadm_19 Apr 04, 2009
    I have de same problem,i can't unlock the sagem my W8,the imei is:356794000233880.
  • Anonymous May 05, 2009
    sem me sagem my w 8 un lok cod.
    [email protected]
  • Anonymous May 25, 2009
    daadasfadv
  • mesteruca172
    mesteruca172 Jul 08, 2012
    plese helpme with my sagem myW-8 imei 356794002112603
dybrice
Imei unlock 332052-35-125357-0 3927257920 332052-35-129377-0 3362230830332016-35-146513-0 1558898480 332052-35-126828-0 4011806542332052-35-126963-0 0079539739 332049-35-321828-0 1503515261332052-35-126971-0 3852379919 332049-35-236282-0 1395096725332052-35-127534-0 0810548649 332049-35-176328-0 0947921989332052-35-128668-0 3830409997 332052-35-176099-0 0948020856332026-35-148914-0 0270060834 332052-35-174998-0 0445933997 Tout d'abord il faut rentrer dans le menu hotline3 du portable. - Pour ce faire, tapez *#06# afin de connaitre l'imei. - Enlevez les six premiers chiffres et le dernier. Il vous en reste donc huit qui doivent commencer par 35 ou 82. Procédez de préférence sur un tél sans carte sim. - Tapez * + les huits chiffres puis OK. Le menu hotline2 est activé. - Ensuite entrez dans le menu normal du tél puis tapez *. allez dans RAM, tapez l'adresse 112, validez, appuyez sur C, tapez 2 en nombre d'octets et validez. Apparait alors à l'écran : adr:112 puis 8967. Appuyez sur modifier ou C, tapez 7698 et validez. Voilà, le menu hotline3 est actif. Ce menu permet de lire et d'écrire dans tous les champs EEPROM (menu normal puis * puis 3, prom) sans câble. - Avant tout, allez dans le menu PROM, lecture/écriture, tapez 231 en champ et validez. Il y a 0 ou 00. Ce champ est le compteur de mauvais codes simlock tapés sur le gsm. Donc si vous en avez rentré le compteur doit être supérieur à 0! Mettez ce champ à 9 ou F s'il n'y a qu'un seul chiffre ou à 99 si y a deux chiffres. Ainsi le compteur est bloqué mais le temporisateur est désactivé, vous pouvez donc taper autant de simlock faux sans aucune incidence. - Maintenant allez dans PROM, tapez 0 en champ. Vous obtenez une série de lettres et chiffres que vous inscrivez soigneusement sur une feuille. Vous faites "annuler" et encore lecture/écriture mais cette fois çi avec le champ 251 et vous notez son contenu. Sortez du menu PROM pour allez dans RAM mais cette fois çi à l'adresse 219 avec 6 octets. Notez aussi le contenu. - Lancez le soft SAGEMSLCK, quand il vous demende de taper "I UNDERSTAND" vous le faites en majuscules obligatoirement. Il vous demande ensuite le choix "par câble" ou "manuel". Tapez "m" (en minuscules obligatoirement) manuel. Le soft demande ensuite de taper les contenus des trois champs eeprom et ram précedents et lorsque vous validez il vous donne le code simlock à dix chiffres.... Et votre phone est débloqué !!!Ca ne marche pas sur certains modeles. C'est peut etre dû a la version du soft qui est peut etre trop récente.Tenez moi au courant. Pour les Sagem 9500 et autres ??? des ptites indications au cas où les manips. seraient pas clairs :"il est difficile de deviner où il faut rentrer le code de deblocage une fois obtenu. Et c'est pas indiqué chez toi qu'il faut faire * apres Menu, etensuite qu'il faut rentrer dans la rubrique Sim lock."
Posted on Jun 03, 2008
Anonymous
Excuse me I'm from Italy and I need the usim-lock codes for my sagem my w 8 the imei number is 3573560007128731 plz help me caus it's totally locked. Send answers to [email protected]
Posted on Nov 17, 2008
Anonymous
There is no solution yet .... but i've a new thing ..!
send to me .. !
Posted on Aug 30, 2008
Anonymous
Hi
[email protected]
Posted on May 05, 2009
    Hi
    imei.no.356794002072401
    252500021/myW-8
    F282/06 N4
    Made in EU
    [email protected]
Anonymous
    New Friend:
Plz help me i have sagem my w-8 mobile it's lockedi can't use it plz send me unlocke code the imei no. is 356794000570257 plz plz plz send me on this email id [email protected] i am very thankful for u.
Posted on Dec 12, 2009
Anonymous
My aphone needs to decoded what should i do
Posted on Jun 26, 2008
Dejan Mitkov
I have locked Sagem myW-8 can u help me with unlock code the IMEI code is: 356794000012441. cend the code on my mail [email protected]
THX
Posted on May 20, 2012
Rafik
I've sagem my w8, I need some help the imei code is: 356794001543469
- my e-mail address is: [email protected]
Thanks
Posted on Jul 17, 2013
zie12
Salut moi mon imei est 356794001624715
pas de 350ou 82 stp dis moi comment faire.
[email protected]
Posted on Apr 06, 2013
muhammad arif
Sir,sagem 3 my W-8 imei is 356794001547155.it dont accept the sim and reply is sim not allowed plz sir tell to this problem
Posted on Sep 12, 2012
Drew Conners
    New Friend:
Help i need an unlock code for my sagem 356794001853025
Posted on Nov 13, 2011
Ali Raza
    New Friend:
    Problem Solver:
  • 5 Answers
My mobile imei 356794001982188 plze send me code
Posted on Jun 08, 2011
  • Ali Raza Oct 08, 2011
    plz send me un
Anonymous
Plz mon imei is 356794001133006 j'ai pas de 35 ni 82 aide moi s'il vous plais mon email est [email protected]
Posted on Jul 05, 2010
  • Anonymous Jul 05, 2010
    plz mon imei is 356794001133006 j'ai pas de 35 ni 82 aide moi s'il vous plais mon email est [email protected]
Anonymous
Mon imei est 357356000011671 [email protected] je narive pas a le faire au debut ya pa de 35 ou de 82 aider moi svp
Posted on Jul 01, 2008
Anonymous
Hi
I have a Sagem my W-8.help me with unlock code
Posted on Jul 19, 2008
Mysql> desc contact_info -> ; --------------
Hi David,
It looks like you're missing two more null's in the third record, the column count is only 21 and you have 23 fields in your destination table.
All your data matches up to the columns, but you'll need to insert ", null, null" before the last paren to cover CompanyURL and companyPhone):
('Karson', 'B', 'Campbell', null, 'Dr.', 'Chief Resident', 'Pediatrics', '[email protected]', null, null, '585-544-1212', 'home', '1955-01-05', 'Wife: Molly Kids: Cassidy, Justine, and Cory.', 'Mountain View Hospital', null, null, null, null, null, null, null, null, null, null )
Sep 06, 2013 | Sun MySQL
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; FunWebProducts; GTB7.1; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media...
- Try a different web browser - Restart your computer - There might be an issue with Facebook itself, so you might have to wait a couple hours - If none of those seem to be the problem, there is a good chance you have a virus.
Jul 06, 2011 | Facebook Social Network
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; Trident/4.0; GTB6.5; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0;...
looking like you have some trash that needs cleaning in your cache folder. Have your browsing history cleaned and do not keep passwords in your system, as they may be vulnerable to theft.
Lemme know if this helps, if not, I will look further into it.
For helpful tips on internet security, you may also visit the site below. It seems free for now on it's building stage. http://bit.ly/otZ0jN
Jul 06, 2011 | Microsoft Internet Explorer 8
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; Trident/4.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; InfoPath.2; .NET CLR 3.5.30729; .NET CLR...
It looks to me like something was coded wrong in a Facebook app. It could be an error which is passed over on other browsers, but the coder of the app trying to use a variable "big_pipe" made a mistake somehwere.
May 04, 2011 | Microsoft Internet Explorer 8
Hi i try to login on facebook and I get this error message.. Webpage error details User Agent: Mozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.1; Trident/5.0; SLCC2; .NET CLR 2.0.50727; .NET CLR...
A programming error on the computer though not from facebook interface software. That could be check verified from another computer without programming variables disconfigured. A programming envirionment communicates with the codes of any software a feature that could set by an expert computer programmer requiring reconfurating or performing diagnostic functionalities. How to disable the program environments.
1. Sign into the internet browser.
2. locate the settings toolbar on the browser, click on toolbar that indicates options.
3. Access the internet settings from where to disable the kind of way the computer recognises data on the network explained
4. reconfigure the internet search setting by clicking browser defaults
5. reconfigure all settings to defaults to achieve internet data recognition after the computer has been altered.
Dec 07, 2010 | Microsoft Internet Explorer 8
100% working IDM fake key block problem
http://atips4pc.blogspot.com/2012/02/how-to-solve-idm-fake-key-serial-number.html
Mar 16, 2010 | Microsoft Internet Explorer 8
MySQL Auto Increase
Try this -
CREATE TABLE users (
id MEDIUMINT NOT NULL AUTO_INCREMENT,
login TEXT NOT NULL,
password TEXT NOT NULL,
PRIMARY KEY( id )
INSERT INTO users VALUES ( null, 'bob', 'mypassword' );
INSERT INTO users VALUES ( null, 'bill', 'pass' );
INSERT INTO users VALUES ( null, 'sean', '1234' );
Aug 04, 2008 | Sun MySQL
Lands Phones Logo
5,324 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
