Question about Epson Xp-400 Small In One
Changed black ink but wont print - Epson Xp-400 Small In One
5 Related Answers
DellTech1
Toby White-Beebe
  • 52 Answers
SOURCE: We repalced the black ink cartridge but it wont print black
Most ink jet cartridges have "multiple" protectors to keep the ink from leaking or drying out and the electrical connectors from getting damaged before they are installed into the printer. You should be removing a plastic cap device for the ink, and typically, a piece of clear tape that protects some copper traces on the back of the cartridge. Make sure both are removed. If it still does not work take it back to who you bought it from and have them check to make sure there is ink in your new cartridge. Typically, you can shake it and hear a liquid sound. Good luck.
Toby White-Beebe
Dell Certified Lead Systems Expert
Posted on Aug 28, 2009
fredtmccoyjr
Fred McCoy
  • 380 Answers
SOURCE: Change the black ink cartridge and now the black
Make sure the tape is off the cartridge, and make sure its seated into the slot. it might be necessary to dab a drop of isopropyl alcohol on the cartridge head to loosen any dried ink, or take it to any photo printing center (or some walgreens) store to test the cart. If it fails, take it back for a replacement cart.
Anonymous
  • 192 Answers
SOURCE: Black ink wont print
Clean the head off where the black is with rubbing alcohol and a qtip. If it won't detect the black cartridge and you went into the printer settings and enabled the black to print as well as the color, then the printer sensor that senses new cartridges and amount of ink level is defective and, unless it is under warranty, it's not worth fixing.
Posted on Sep 01, 2009
Henry Alicea
  • 71 Answers
SOURCE: wont print black ink but prints other colours
Clean print head with alcohol and cotton swab maybe dried up
Posted on Feb 19, 2010
Alun Cox
  • 2679 Answers
SOURCE: epson d88 printer wont print black ink even though it full
Print nozzle check and clean heads if necessary.
Posted on Jul 24, 2010
- I have just changed the black ink and now it wont print so I have changed the black ink again and it still wont print anything black - any ideas
The black ink nozzle in the print head might be blocked. Print a test page with a huge black image. Like: just start word, create a square through "illustrations" and fill it completely with black. Print it once or twice and see if finally the black ink may come out.
Through printer properties (windows control panel) there might be additional cleaning options.
Feb 24, 2015 | Office Equipment & Supplies
I dont have any coloured ink cartidges left and need to immediately print some forms in full black will be okay but i cannot change my colours to black as the ink holder stays on the far right of my epson...
To print in all black, you can change a setting through the computer to tell the printer to only use the black ink. This is better than putting black ink where the color ink normally would go as that would cause the shading to be wrong and potentially ruin the documents.
If you have enough black ink in the printer, before you finalize the printing process make sure you have black and white only selected.
This will allow you to print without getting access to the ink cartridge holders.
Good luck hope this helps.
Mar 11, 2011 | Epson PRINTER, 4800 PORTRAIT EDITION...
New ink wont print black.
cheak the printer properties and setting
Thank U sir...All the Best...
Apr 22, 2010 | Lexmark X5470 All-In-One InkJet Printer
Wont print black
Change the black ink cartridge.
Jun 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Wont print black because it doesnt have color ink
So for now, you can change the print settings to only print in black.
Change the print properties/ colour to grayscale.
May 11, 2009 | HP PSC 1610 All-In-One InkJet Printer
New black ink wont print
goto printing preferences in printer and faxes. open properties oof printer. change print quality to best or maximum.
Apr 24, 2009 | Office Equipment & Supplies
I replaced all the ink and my brother mfc 240 still wont print black, or copy black, or test print black
i replaced all the ink and my brother mfc 260 still wont print black, or copy black, or test print black
Mar 24, 2009 | Brother Multi-Function Center MFC-240C...
My printer wont print, plus the black ink seems to not work
maybe your ink cartridge is damaged. Try to change your ink cartridge (black). Or your printer has reach the maximum capacity of pritning.. ^^
Jan 28, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Epson Xp-400 Small In One Logo
43 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
