Question about Pride Mobility Products Health & Beauty
Nothing works no light no power - Pride Mobility Products Health & Beauty
Why does nothing past the first connector work?
Check for broken wires/connections on both sides of the connector.
Nov 30, 2015 | One Stop Gardens Solar Rope Light
Toshiba L750D Laptop won't turn on, no power light nothing,
Could be a faulty power supply. Try getting a universal replacement and see if that works. Take the laptop to a computer store and see if they have one for you to try before you buy.
Sep 17, 2014 | Toshiba Computers & Internet
Green power light comes on goes off then on again stays solid, moniter says no signal, mouse lights up, and three red lights on key board flash then nothing why?
If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Nov 21, 2012 | eMachines EL1852G-52W
My D-7 will not power up...when turn it on the power light weakly flickers (as well as the power sound) for only sec then nothing. Have cleaned battery connections, used charged batteries and even to
Sounds like electrolytic capacitor dried up needs curing, which is power on capacitor and left it absorb some moisture in humidity on power. Some time a few minutes, hard cases may take a few days.
Feb 08, 2012 | Konica Minolta Cameras
The power light is working when charging but nothing is working
I read there is a problem with the hinges so i placed a knife between top & bottom screen and twisted it about lightly and it came back to life.
Oct 01, 2009 | Nintendo DS Lite Console
No Power
HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
Jun 01, 2009 | Kenmore 62702 Microwave Oven
No power. No lights.
I have the exact same problem.
TV was working fine (if you call having to deal with blinking lights of death and multiple starrt up errors...) - but I powered through it all.
This TV is 6 years old and started acting up after the 4-year extended warranty ran out.
This morning I went to turn it on and nothing.
Hmmm... Got my manual to count the blinking light code...
Whoops. No lights. Nothing. Checked plug. Checked power.
Uninstalled and installed lamp. Checked plug and power again.
Nothing.
Not one stinking light. No power to fan. Nothing.
How does a TV just DIE???
Mar 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Does not switch on and there is no orange chg.light or green ligh
Your' battery may be bad, have gotten disconnected, or the battery is dead, and the charger is bad.
Dec 29, 2008 | Sony DVP-FX810 Portable DVD Player
Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Health & Beauty Logo
16 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
