I have a 2000 jeep grand cherokee and the keyless remote wont unlock the doors and when I hit the lock button it doesnt chirp like it used to and it wont lock the doors. How do I fix this?
Go to autozone and use the remote tester on the counter to make sure that the remote itself is functioning or not, could be a dead battery. On some vehicles it is possible to reset the keyless entry by turning the ignition switch from off to run (right before the starter activates) 3 times or so, if you try this and the door locks activate then press the lock button on your remotes. good luck
Unlock all of the Jeep Grand Cherokee's doors and open the driver's side door. Keeping the door open, lock it using the manual lock on the door itself.
Put the manual key into the ignition and switch it to the "On" or "Run" position, whichever applicable, without starting the engine.
Control any distant PC remotely. Test the Software now for Free!
www.TeamViewer.com/Remote_Control
Point the remote at the receiver (located by the little bulb on the car ceiling) and hold down the "Lock" button for up to 5 seconds.
When the driver's side door unlocks, you know the remote has been programmed correctly. If you are only programming one remote, jump to the next step. If not, manually re-lock the driver's side door and repeat steps 5 and 6 using each remote you would like to program and then continue.
Turn the key to the "Off" position and turn the ignition on immediately. This must be done within 20 seconds of programming the last remote. You're finished!
