I have moved the printer to a new office so the internet address may be different. I need the printer administrator code nd the pin code.
SOURCE: Canon 210S Image Runner
It is a fixing film position error. The fixing film is probably damaged or is just tracking off center. If the fixing film is ratched then replace the entire upper fixing unit. You can get just the film but its a job even experienced techs cringe at. Check the lower roller and bushings while you are at it. If anything is worn there it can cause the film to track off center.
SOURCE: Canon Image runner C 3200 printer gives error code E000677-0080
your quickbooks file is in the wrong format example tiff or pdf let your it know they can change it to the correct file format
SOURCE: about error code
cannon ir 5000 copier give me error e 0061 & e0069 what the problem and the solution
SOURCE: canon image runner error code E000000-0000
Note that clearing the error may not necessarily fix the fault.
Press the * with a circle around it then press 2 and 8 at the same time.
Then press * again.
Press copier touch button / function / clear / error /ok button then switch off.
Switch the machine back on.
The error code indicates that the machine doesn't sense the temperature of the fuser getting hotter. Usually this calls for the fixing film unit to be replaced because the thermistor has gone bad.
SOURCE: Canon image runner 4570 in error code E000100-0001
Ok here is how to reset the error if that doesn't work... you really need to call a tech... you are going to need some serious work done on your copier... ok... here are the instructions
press additional functions
press code error
press copier
press function
press clear
press error
press ok
press reset
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
