Question about GE JTP20 Electric Single Oven
Ge monogram zet 1038 door won't close - GE JTP20 Electric Single Oven
GE monogram double oven . Self cleaning top oven and F9 in red showing and beeping noise
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Jul 17, 2016 | GE Monogram ZET3058SHSS Stainless Steel...
Ge monogram bottom oven won't clean
Follow the owner manual instructions, some condition is not set or the door switch or door lack it not operationg. Could be the monitor switch on the oven latch.
Mar 02, 2013 | Ovens
Doors do not close all the way and the problem is getting worse
the door hinges generaly cause this problem and will have to be replaced . some cn be shimed but best to replace them in sets // do not do one only. or you get to do job over . mm
Jul 15, 2010 | GE Monogram® ZET1058 Electric Double...
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
Door won't close properly
Very common problem, when door is not closing all the way. You need to pull it out a few inches and readjust hinges on each side.
Ge monogram oven repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | GE Monogram® ZET1038 Single Oven
Door on GE JTP18 oven does not close tightly.
Not sure if this link will work, but give this a try
http://claimworks.servicepower.com/mfgltr/I404/RC/Wall%20Oven%20Repair%2011-4.pdf
There is a recall on the oven door for a few models
Safety Recall GE Wall Oven Models Included in the Recall
Brand Model Numbers Must Begin With Serial Numbers Must Begin With GE® and GE Profile™ JCT915, JT912, JT915, JT952, JT955, JT965, JT980*, JTP20, JTP25, JTP28, JTP48, JTP50, JTP86 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF GE Monogram® ZET3058, ZET938, ZET958 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF Kenmore
(All model numbers start with 911) 4771, 4775, 4781, 4904, 4905, 4923*
* Lower Oven Only 2T, 2V, 2Z, 3A, 3D, 3F, 3G, 3H, 3L, 3M, 3R, 3S, 3T, 3V, 3Z
and that link shows the door and hinge. Recall info at
http://www.geappliances.com/products/recall/wall_oven_08/
May 31, 2009 | GE JTP20 Electric Single Oven
Ge monogram single convection wall oven
There is usually a micro switch that is activated when the lock lever is in place - very likely this switch is still activated or has failed closed (defective) .
Aug 26, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Ge double oven
I believe this is because it takes a while for your oven to cool down (the cleaning cycle uses a very high temperature to burn up the grease and food). The timer is how long it takes before it will be cool, at which time the oven will unlock.
Mar 17, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
GE JTP20 Electric Single Oven Logo
107 people viewed this question
Top GE Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
