Question about Bosch DWM40L Miter Finder Digital Protractor/Angle Finder
MY BOSCH DWM 40I DIGITAL ANGLE FINDER WILL NOT TURN OFF & STAYS ON THE START UP SCREEN
THE ANGLE FINDER WILL NOT TURN OFF UNLESS YOU TAKE THE BATTERIES OUT, THE SCREEN DOES NOT ALTER FROM THE START UP & WILL NOT NOT READ OFF ANGLES AS YOU MOVE THE ARMS
2 Related Answers
domotek
Tommy
  • 591 Answers
SOURCE: battery compartment in my angle finder overheats
There is an electronic component that is defective and it draws a lot of current (more than the normal rating) this makes the batteries over heat, if it's new ask for replacement of the tool.
Cheers!
Posted on Jan 12, 2011
Chad Triggs
  • 5 Answers
SOURCE: My Bosch DWM 40L angle
Open the the moveable arm and make it straight (180 degrees) or in line with the other.Take the screw off of the black cover at the elbow (1 screw). Lift from the round part and lift off. Then loosen the two screw just inside the cover. This will allow the flywheel to spin and you should now get a read out. If the flywheel does not spin then you need to replace that piece. Gently tighten the two screws and put the cover back on. Hope this helps!
Posted on Nov 07, 2011
My Bosch DWM 40L angle finder has locked itself on 888.8 and I can not swithch the machine off, even when I put in new batterie it does not correct itself, please can you help.
Aug 15, 2011 | Bosch DWM40L Miter Finder Digital...
Bosch DWM 40L, Cannot seem to resetit,it reads 888.8,it wount even switch off.
Feb 24, 2011 | Bosch DWM40L Miter Finder Digital...
Bosch dwm 40 L. how do i calibrate it or where can i send it
The manual states this tool needs no calibration. I spoke to the service rep at Bosch, and he confirmed there's not 'published' way to do it. There are a number of outside firms that will do it. If you call Bosch support and explain the problem, they should send you a mailing label and calibrate it properly. Depending on if it's in warranty or not, there may be a fee for calibration and the return shipping.
Feb 21, 2011 | Bosch DWM40L Miter Finder Digital...
Battery compartment in my angle finder overheats and battery indicator comes on a brand new set of batteries . why is that? i put a fresh set of batts.and when i turn it on the batteries on the right get...
Cheers!
Jan 12, 2011 | Bosch DWM40L Miter Finder Digital...
Turn on camera..view finder and/or display screen
The s7000 has three different display modes: Screen, viewfinder, and off. Screen is for looking at the big screen, viewfinder is for looking through the digital viewfinder, and off should turn off all the displays. Try pressing the DISP button once. That should reactivate the screen and make it possible to use the camera again.
Jul 25, 2010 | Fuji FinePix S7000 Digital Camera
Look i have a phoenix digital PD 395 and when i
some amps require more than 500 milliamps to keep it "turned on" most head units put out half of that ,bosch relay inline from deck to amp turn on post should do it this will give the amp a full 12 volts to turn on and stay on . first try to hit the maps with a jumper with 12volts fused , see it it stays on
Jan 07, 2010 | Car Audio & Video
Large viewfinder only works when reversed &
dear ... there is an option in the menu .....
of hvr A1 TO KEEP THE VIEW finder.... ON..
write nw
ur camcorder is in auto mode ,wht happen in auto mode is ,view finder gets ON only when u turn the LCD pannel ...
so need nt worry change ur MENU option OF view finder from AUTO to ON,......
Jul 13, 2009 | Sony HVR-A1E HDV Digital Camcorder
Skil 2100daf angle finder
I was trying to reset the zero on my angle finder. It's a Powerfist Digital Angle Finder, the same as the Skil 2100.
After turning the unit on, if I press the Miter and Hold button together and hold them, the unit goes into 'calibration' mode. (The display flashes 0.0). If you do nothing, it will always stay in this mode forever after that.
You can then reset your unit - it takes time however and patience.
With the aid of a large protractor, draw angles on a large sheet of paper (I used a couple of 11 X 17" pages) from 0 degrees all the way up to 220 degrees.
Turn on your angle finder and make sure the numbers are flashing 0.0. This will be your 0 degree reading. Hold the finder closed and press the Hold button once.
The display will now read 10 degrees. Open up the finder until it matches your 10 degree marks on your paper and press the Hold button again.
The display will now read 20 degrees. Open up the finder until it matches your 20 degree marks and press the Hold button again.
Continue setting your angles in this fashion up 'til you reach 220 degrees. The next button press will close the calibration cycle and the numbers will stop flashing.
Your unit is re-calibrated. Now, if it's off - you've only yourself to blame.
Apr 23, 2009 | Skil 2100DAF Digital Angle Finder
Camera will not turn on. As I rotate the selector switch the light flashes at each position. Even when I switch it to off the off light flashes on and off. The screen stays on but it is blank.
Hello, Did you try pressing the little silver button marked "EVP/LCD" it is located at the left of the view finder,This turns the screen on and off.
Hope this takes care of problem.
Best Regards, Russell
Feb 06, 2009 | Kodak EasyShare DX6490 Digital Camera
Bosch DWM40L Miter Finder Digital Protractor/Angle Finder Logo
310 people viewed this question
Top Bosch Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Bosch Measuring Tool and Sensor Expert? Answer questions, earn points and help others
