Fuji FinePix 6800 Zoom Digital Camera Logo
A
Anonymous Posted on Jan 26, 2014
Inserted card wrong way now not working
Put card in camera wrong way and now camera buttons for setting date don't work and grid like affect down rh side of screen
3 Related Answers
Anonymous
  • 216 Answers
  • Posted on Apr 17, 2008
SOURCE: xd picture card
Greetings FredericoIV,
A common fix for this issue is to use an external card reader, and reformat your card using your computer. Make sure you chose FAT format instead of FAT32 or NTFS.
I hope this helps.
Thank you,
Agent Dort
Go Ahead. Use Us.
Anonymous
  • 71 Answers
  • Posted on Jun 19, 2009
SOURCE: Flash setting doesn't work
Does your camera gave a small battery in place somewhere that is used to maintain the date and time settings? (it is generally a watch battery type small flat silver disk.) You should not have to reset time and date after each battery change.
Many digital cameras eat up batteries quickly, especially when using the flash alot., that is why it is important to use good quality rechargeables whenever possible.
Anonymous
  • 153 Answers
  • Posted on Feb 28, 2011
SOURCE: I have a Fujifilm Finepix
Try reformatting the SD Card. If you have a computer with an SD card slot, insert it in there, right click on the card, and click "Format..." If you use a Mac, use Disk Utility to format the card.
I TOOK PICTURES AND THE DATE WAS NOT SET CORRECTLY NOW THE STAMP ON THE PICTURE HAS THE WRONG DATE HOW DO I CORRECT IT ... I DO NOT WAS TO PRINT ANY OF THESE WITH WRONG DATES PLEASE PLEASE HELP!!!!
You cannot change the dates on the taken photos using the camera.
Copy the pictures to your PC, and use a graphic editor to put the new date.
It is a very difficult task to change the date displayed. Therefore insert a button-like graphic on top of the date and put the correct date over that.
5answers
"how can i put a
Press Menu - If you see a Setup tab , press the right arrow button to highlight the Setup tab. - If you dont see a Setup tab, press down arrow button to select Setup, then press OK button. -If your camera doesn't have a Menu button, press the Review button then choose Settings.
Press the down arrow button to choose Date & Time the press OK button.
Press the Right/Left arrow buttons to move between year, month and date.
Press the Up/Down Arrow button to scroll through the year. month and date.Use the same procedure to set the Time.
When finished press OK button.
Hope this helps. Rate if it works. Thanks
May 04, 2011 • Cameras
4helpful
How do you transfer photos on a kodak m863 from internal memory to an sd card?
Insert a SD memory card. Set the camera's image storage location to "internal memory". Press the Review button, then press the Menu button. Use up/down to highlight "Copy" then press OK. Select an option and press OK.
To set the camera's image storage location, press the Menu button then use up/down to select "Image Storage." Don't forget to change it back when done.
Hope this helps.
Apr 28, 2011 • Cameras
3helpful
I need to put a date stamp on my photos and need to know how to do it.
The date stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution. Then press the menu button. Select the "Camera" menu, then scroll down to the the Date Time Stamp selection to turn it on.
7helpful
Cannot turn on date stamp
The date stamp only works in "Postcard" resolution. Press the Func Set button, then scroll down to the bottom to select postcard resolution.
Then press the menu button. The date time stamp selection should now work. Simply turn it on.
13helpful
2answers
Canon sd 750 how to put the date in the picture?
here is the solution:
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
To set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm14-520511.jpgyour date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
[email protected]
2answers
My pictures won't go on the computer
I also had this problem intermittently. Sometimes it worked, sometimes it didn't. Sometime rebooting cured it, sometimes it didn't.
In the end I got frustrated and bought a USB-connected CF-card reader (they're fairly cheap these days) and now if it doesn't work, I just pop the card out (using "eject" button on the bottom) and put it in the card reader into the USB port. It works every time, and is also much faster than the direct-from-camera transfer.
No memory card, set time
The date/time battery is "built in" (not replaceable) to this model according to page 13 in the manual (available here). It is supposed to recharge when you have the regular battery installed, but if you leave the regular battery out for more than "approximately three weeks", the internal battery may go flat.
I'm not sure this has anything to do with the memory card issue, though. Check the battery problem by inserting a freshly charged battery, turning on the camera and setting the correct date and time, then turning off the camera and waiting an hour or so (with the main battery still in the camera). Turn the camera back on, and if the date and time have to be reset again, your internal battery may be bad, and the camera would need to be serviced.
Managing the Time and Date
I have found the answer to the date problem. The date is hidden and will not show up unless you insert it during printing. When printing in ACDsee select print image, then click on the CAPTION tab, and de-select the box the says "insert date at lower RH corner" or somthing like that. Once it is de-selected it will stay off untill you select it again. By the way you can look into the camera with Microsoft explorer, or any program to copy or open the picture. In my case it is "drive G". I opened Photoshop and drilled down into the camera through drive G, and was able to open the photo without any special dedicated program.
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
