Question about Samsung CLP 315 Laser Printer
Solid orange light won't go away i don't what the problem is
Posted by nawalhangol on
dukes1000
    New Friend:
  • 4 Answers
Install the Samsung universal printer drivers (I think from Samsung site). Once installed add your printer.
Use the Universal printers as your printer to print to.
It may then tell you exactly what the problem is. Could be anything from paper jam, to empty ink, to drum fault.
Posted on Jan 27, 2014
After about fifteen minuetsof playing it turns it self off it also feels warm to the touch
Solid green or solid orange light: Your power supply is working.
Flashing orange, solid red, or no light: Your power supply may need to be replaced. Try the following solutions:
  1. Try plugging your console's power supply into a different electrical outlet. Do not use a surge protector.
  2. If the power supply light is solid red or flashing orange, unplug the power supply and let it cool for 30 minutes. Then, plug the power supply back into the outlet.
There is no crack or damage done to it right?
Also try plugging it into the wall dirteclty no surge or power strip and let it lay flat
Nov 19, 2013 | Microsoft Cpa09-010a Ac Adapter Xbox360...
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
Solid orange light
If your printer suddenly got disconnected from your network, try to move it away from any interference and closer to your router.
If the WiFi light is on solid orange then it's totally disconnected from your network. You'll need to reconnect your printer back to your network. Just run the Wireless Configuartion Utility.
To access that, on your computer, click on Start > All Programs > Lexmark 3600-4600 Series > Tools > Wireless Configuration Utility.
May 19, 2012 | Lexmark X4650 InkJet Printer
Poweredge SC 1420 won't come on, it keeps blinking an orange light on the power button and the lights below the power button the first 3 indicator lights are orange. I tried unplugging and plugging it...
hi,
I have several of these and most often there power supplies blow. since they come by default with only one powser supply. the system won't start
I would start there as most other problems will generate beeps.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 17, 2011 | Dell PowerEdge SC1420 (SC1420MIN) Server
Panasonic kx dt 333 When the phone rings the red light doesn't flash to denote which line it's coming in on. Any idea how to resolve this?
Which means what? You have a solid red light on the line or you don't have the line at all. A TDA system rings by a process called ICD groups. You can have a phone in an ICD (600 by default) and tell it the number of rings to delay, not ring, or immediate ring, but that means that the line button will flash as the call is coming in. If you don't assign it to a group, it's really stupid and won't do anything but light solid red.
If you have access to installer programming, you assign the extension to the main ICD. If you don't you have to call your Panasonic installer or dealer.
Carl
May 11, 2011 | Panasonic KXDT333 Phone
I have recent6ly had to have a new router and since then the Lexmark X6570 printer we have won't work,I have concluded that the ip address needs changing to the current one but don't know how to do...
Try to reset the wireless network adapter of the printer. On the printer operator panel:
- Press Settings to display Settings
- Press pattlnk_5182007_1524-left_new.jpg to display Settings
- Press pattlnk_5152007_204-checkmark_alone.jpg to display Network Setup
- Press pattlnk_5182007_1529-right_arrow.jpg to display Network Setup
- Press pattlnk_5152007_204-checkmark_alone.jpg to display Wireless Setup
- Press pattlnk_5182007_1529-right_arrow.jpg twice to display Wireless Setup
- Press pattlnk_5152007_204-checkmark_alone.jpg to display the scrolling message This will reset all wireless network adapter settings. Are you sure?.
- Press pattlnk_5182007_1524-left_new.jpg or pattlnk_5182007_1529-right_arrow.jpg to change the value from No to Yes, and press pattlnk_5152007_204-checkmark_alone.jpg.
The WiFi light on the printer will momentarily turn off. When it lights up solid orange, launch the Lexmark Wireless Setup Utility on your computer by inserting your installation cd or executing the Lexmark X6570 driver. Follow the instructions on your computer screen.
May 05, 2011 | Lexmark X6570 InkJet Printer
Canon i950 won't print
try this Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
one by one
Jan 25, 2009 | Canon i9900 InkJet Photo Printer
Samsung CLP 315 Laser Printer Logo
196 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
