Washing Machines Logo
B
Brenton Cunningham Posted on Jan 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fisher & Paykel GW612 won't spin
The machine start its spin/drain cycle, but stops after 1 sec. Have drained, checked for clothing jams etc
reliableservice
Level 2:
Sergeant:
  • Expert 314 Answers
  • Posted on Jan 27, 2014
reliableservice
Expert
Level 2:
Sergeant:
Answers
314
Questions
Helped
67828
Points
873
You want to check the drain pump if there is nothing stuck there sometimes a drain restriction will cause the machine to stop
1 Related Answer
Anonymous
  • 10 Answers
  • Posted on Aug 03, 2009
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Fisher and paykel washing machine top loader doesnt spin dry the clothes well. There isnt any water in the machine after the spin cycle but the clothes are heavy wet. What's could cause this?
Machine not spinning. Have you stood next to machine and listened? When all water is drained out (watch the drain hose for water to stop) then you should hear the spin start and hear it building up speed. If it doesn't then you need to post back here with more detail on what you could hear or see happening. i.e. how long after water stopped draining did machine finish and switch off?
My F&P GW601 stops during final rinse, and beeps an error condition.
  • I just fixed a F&P GW612. There was a darning needle stuck in the drain motor pump stopping the propeller from spinning around. I fixed it for my mum by watching a couple of You Tube videos. Easy job to do. Took me about 1.5 hours including drawing out the water from the drum with a bucket & jug first. Lay the machine on a soft mat, remove the motor pump from underneath, clean it out. (You could find a foreign object such as a coin, cloth, rubber band etc.)
    Put it back together & test if it's pumping out water at the rince cycle by doing a low water wash cycle. So happy, job done & I saved my mum some money!!
How do you ascertain if its drain pump or faulty controller board causing a fault 37 on a gw612?
Read the answer in the link below first, but in your case it can also be a faulty or blocked diverter valve. If you are good with a multimeter check the resistance of the pump windings. It should read around 33 ohms. It is not uncommon for the pumps to cook themselves and you can smell and see the burned out motor. I hope this is of some help
http://www.fixya.com/support/t25754844-error_code_37_fisher_paykel_8_5_kg_front
Fisher & paykel gw612 washer constantly trying to drain
The pump triacc in the motor control board needs to be replaced
by a technician, it's cheaper than getting a new board.
14helpful
3answers
2helpful
Stops before rinse cycle... won't drain or spin.
The REGULAR CYCLE button turns the drain pump on or off. The REGULAR LED will turn
on when the pump is on. This feature can be used to drain the tub. You could get a bucket and lay the hose on the fllor. Gravity will drain it down.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
17helpful
3answers
Hi there
Nick
2answers
Fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
