Question about Whirlpool LSQ8243H
Is the LSQ8243H a 3.9 cu inch tub
How big is the tub?
HOw do I change the bairing on the drum R
You didn't mention brand, but that wont matter much.. This is big job. you have to tear down the entire machine from the front and back, remove the front of tub, remove the bolt holding shaft in back of drum, beat or pull out the inner basket and shaft out of damaged rusty bearings, then, depending on model, you either have to pull and replace bearings and seals in outer tub, or replace the entire outer tub with bearings and seals pre-installed by factory. If you have manual, it takes about 4-5 hours first time. Experienced techs can get it down to 1.5-2hrs. But regardless, its a big job.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/perry_14036f9bc71cde6a
Jan 12, 2015 | Washing Machines
My old toshiba t.v. has short bodys and big headed people in the screen do i need to replace a tub ?
Yes you must replace the tub, with that brand tho the more expensive the tub, the more efficient it will make your Toshiba viewing experience.
Jul 21, 2012 | Computers & Internet
Model #AWM392W when water is filling tub, water is coming out from around the bottom
the outer tub seal is bad,you need to remove the inner tub then outer tub to replace this seal
Aug 07, 2011 | Speed Queen AWS52NW Top Load Washer
Leak under machine from right rear of washer
you need to check all hose fittings if not there and this is an old machine it may be the tub
if tub you will have to remove spin tub and patch rust spots on the main tub clean rust and patch with epoxy
this is a big job if the machine is old parts will be frozen in place
Jun 09, 2011 | Kenmore Washing Machines
My washer has a strong noise in the braket wen is in spin psae on cicle. I thin has the transmition broken.
check for wobble in spin tub only not main tub if so tub is rusted on centre post and can be replaced
big job
Jun 09, 2011 | Washing Machines
My washer is leaking big time. I've checked the pump and associated hoses and they look fine. How big of a deal is it to take the tub out and start checkinh in there?
I HAD THE SAME PROBLEM. I REPLACED THE PLUME (SP?) TOOK CARE OF MY PROBLEM. (THIS IS WHERE THE WATER GOES INTO THE TUB WHEN FILLING UP)
Hh
Oct 06, 2010 | GE Washing Machines
Bearing noise at back of tub assembly.
sounds like jet taking off when it goes into spin
model # mah40000awq
Apr 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
117 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
