Remove the negative battery cable, connect an amp meter in series, between lead and battery terminal, should have a reading of approx 0.05 amp (Time Clock). If higher, then there is a drain, remove the fuses one at a time and watch for a drop on the amp meter. when it does you have found the circuit giving trouble. I would expect a reading of about 8 amps if it's the defog causing the problem. You could try taking the defog switch out first to see if that's the problem.
