Question about Patio Heaters
My propane outdoor heater lights and generates heat on low but when i turn control to high the flame and heat do not increase
Covered all the details
Posted by Doug Gage on
Joseph Mueller
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 346 Answers
The troubleshooting manual says low fuel, low fuel and cold weather and kinked supply line. Beyond this I would need to know if something happened to the unit like it fell over or was taken apart. Best, Joe My propane outdoor heater lights and generates hea - 1_31_2014_3_36_44_pm.png
Posted on Jan 31, 2014
Hi i have a progaz heater the the pilot light won't stay on it starts the heater then flickers for a bit the go's out
Defective thermocouple. It is the metal tube that stays in the path of the pilot light flame.
3answers
Patio heater fell over and now not working could it be the flame screen needs to be replaced
????????????????????????? Whatevers Broken / Damaged needs replacing
1helpful
2answers
I tried the little buddy heater in my golf cart and as soon as I move the cart the heater goes out what can I do to stop this
This is not going to work in your golf cart. This is propane based heater with a pilot light. It will go out if you drive because of the wind blowing on it. I also believe all Mr. Heaters have a tip hazard turn off. I know the two I have do. If you really want heat in your cart I would recommend an extra battery, an inverter and a porcelain electric heater. Could be made to work very nicely in your cart.
1helpful
Why won't my patio heater light
The thermocouple has to be in contact with the flame at all times when pilot is lit, this heats up and sends mill-volts back to the safety valve to keep the gas on, if not it won't let the gas through, otherwise you need to clean the pilot or replace the thermocouple if everything else is ok..
Lava heater won't light
Try using a match, sometimes spark is not hot enough. be carefulle.
1helpful
No Flame
It could be dirty nozzle or dirty line
Unscrew every thing in the nozzle and control valve section and clean gas line and reinstall and try it
2answers
My pro temp dual propane burner heater will light but won't stay lit
Either the temperature probe (at the pilot light) that signals the gas valve to open is defective or the gas valve is.
4answers
Are electric patio heaters bad for the environment?
there has been some debate about it, in America they are seen as environmentally friendly, but in the UK they are seen as more carbon intensive
2answers
I have 2 sunjoy G-PH001PSS, when attached to the propoane tank, th unit does not light. I do not hear any gas whe turn the control knob to the on position. When i remove the gas line from the heater the...
Greg...
The lighting PROCESS involves HOLDING that
"PRESS MODE" for QUITE a (long) WHILE...
To clear the AIR out of your fuel line...
I have seen ... Up to 5 minutes
although I believe that is excessive)...
It is MOST LIKELY your troubles are procedural.
(READ the manuals)
ELSE
Blue Rhino
is the place to START ... or SEARCH
locally on the internet...
Try (they have manuals here... also)
Blue Rhino Outdoor Gas Heaters
Hope this helps
Carnac the Magnificent
Patio Heaters Logo
Top Patio Heaters Experts
deton8 von Splosion
Tom Chichester
Jerry Kramer
Jerry Kramer
Are you a Patio Heater Expert? Answer questions, earn points and help others
