What is the reset sequence to this dishwasher as I need it to make so I don't have to flip the circuit breaker
SOURCE: we have Frigidaire 24 in. FDB1050REC dishwasher.
more than likely fuse is gone in plug. take dish washer out. change fuse in plug. if it doesnt work get extension lead and run it from a socket that definatly does work and plug washer into that. if nothing then its internal.
SOURCE: i need to flip my circuit breaker on my dishwasher
you may have to many large appliances on the same circuit. you might try to
see how many appliances are on that circuit. if it is so try turning off other appliances and just run the dishwasher to see how it runs. if this works you
may need to increase the amperage on the breaker or split the electrical
circuit. if its on its on breaker try increasing the breaker amperage. good luck!
I appreciate your inquiry, friend!
Based off what you have described you need the reset code for your Frigidaire dishwasher, FFBD2406NS0A. I was unable to locate a specific code for your dishwasher. The best way to reset your washer is to disconnect power from it for roughly ten minutes and you can do that by flipping the household circuit breaker. I hope this is helpful. -Matt
Hello friend, thanks for your inquiry!
On your Frigidaire dishwasher "i30" stands for aqua control. You should perform a reset on your dishwasher and that could clear any false error codes. To reset your dishwasher you can flip the household circuit breaker off for ten minutes. If that does not work you could be experiencing an issue with your water inlet valve or control panel. I hope this information has been helpful. -Matt
Hello friend, thanks for your post!
I see that your Frigidaire dishwasher is not starting. I would perform a reset on your dishwasher and you can do that by disconnecting power, either by unplugging or flipping the household circuit breaker, for ten minutes. I hope this helps. -Matt
Hello friend, that's a great question!
To perform a manual reset on your Frigidaire dishwasher you would need to disconnect power to your appliance. The best way to do that is flip the household circuit breaker for roughly about ten minutes. Hope this is helpful. -Matt
Hello Sean Luther - Generally, the dishwasher can be reset by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit.
Hello - You may reset the dishwasher by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If it proves to be ineffective and the dishwasher does not start, may possibly have a faulty door switch.
Hello - Try resetting the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a communication issue with the control panel or wiring failure which would need further diagnosing.
