Question about Kenmore Elite 12-Cup Drip Coffeemaker, Brushed Aluminum
Time setting - Kenmoore Drip Coffeemaker 100.407063 10
I was ok with setting the time and auto brew for the first time. When I hit the brew button the next morning, the clock display changed to 5. 0. I've unplugged to reset but the time format is still 5. 0 and only goes to 9. How can I change the time format back to normal?
Posted by Robin McDuff on
  • Robin McDuff
    Robin McDuff Jan 29, 2014
    I exchanged the coffeemaker for a new one, which is working fine.
4 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Kenmore microwave
If this has a controller that runs a microwave and an oven, then the problem F2 means a temperature related fault such as a bad temp sensor / thermostat or a defect in the control board. If it's just a microwave, then the problem is likely a failing keypad. In many cases, those can be replaced economically. If you repost with your exact model number (62622 is not a complete model number) then we can advise you further and more specifically.
Posted on Nov 25, 2006
Anonymous
  • 323 Answers
SOURCE: low temp alarm goes off on Kenmore upright freezer
The alarm is there for a reason. I wouldn't disconnect it. Maybe the compressor is low on gas. If your thermostat is on extremely low, try moving it up to a less cold position. Look in your owner's manual for recommended settings.
Failing that, get ready to shell out some bucks to the service man!
Posted on May 12, 2009
Anonymous
SOURCE: Clock display won't stay lit
Same thing happened to our Kenmore range and I found a solution on the web about fixing this problem on a fridgedaire range. It was to hold down the clock button for an extended time ~15 sec. It worked for our kenmore and hopefully for yours too.
Posted on Feb 10, 2010
I do not know how to set the timer on the B60
OK - here you go:
1. Hit your menu button
2. The first prompt is to set the clock, if you do not need to reset your time - then just hit the menu button again.
3. Your next prompt is for auto off, this'll set it to cut off after a specified time. However, you also want it to come on at a specified time right?
4. Hit menu again. This takes you to auto on/auto off (a.k.a. your timer). From here simply use the buttons to the right or left of the menu button to set the time (watch out for am/pm).
5. Flip thru the last 2 menu options of brew temp & brew size. Make any changes you want to there.
6. Finally you'll end up back on the home screen - if you set the timer, then you will see "ONOFFTIMESET" on the home screen.
Jul 12, 2011 | Keurig B60 Coffee Maker
Greetings: Problem with auto grind Cusinart DGB600 coffeemaker. Properly prepared coffeemaker to brew coffee but noticed time is replaced by - - - . Suspected it was time to replace cleaning filter, which...
sounds like the coffee maker had a power surge. Try setting the time again.
1. Setting the Clock When the coffeemaker is plugged in, 12:00 will appear until you set the time. Entering "Time Set" Mode: To set the time, hold down either the "Hours" or "Minutes" button until the clock begins flashing (about 2 seconds). You are now in the "Time Set" mode and can operate either button to achieve the desired setting. The buttons can be held down to scroll through the digits, or pressed and released lightly to advance one digit at a time. When scrolling, the numbers will advance slowly at first and then speed up to the rate of about three per second. When the number displayed approaches the desired setting, release the button and press repeatedly to advance one digit at a time. Be careful to make sure that the PM indicator is on if a PM time is desired. Exiting "Time Set" Mode: The "Time Set" mode can be exited in one of two ways: 1. Press any button besides the "Hours" or "Minutes" button. This will exit the "Time Set" and activate the selected function. 2. Do nothing. If neither the "Hours" nor "Minutes" button is pressed for a period of five seconds, the "Time Set" mode will be exited. 2. Setting the Program Ti m e : When you press the "Program Set" button, it displays the current program time (default time 12:00 p.m.). Entering "Set Program Time" Mode: Press and hold the "Program Set" button (about 2 seconds) until the green light and LCD display begin to flash. This signals that you have entered the "Set Program Time" mode. The desired time can be set by pressing the "Hours" and "Minutes" buttons to scroll forward through the digits. Pressing and holding either button will allow you to scroll continuously, slowly at first, and then to accelerate to the rate of about three digits per second. As the desired time setting approaches, release the button and then press repeatedly to advance one digit at a time. The coffeemaker will start to brew at the programmed time. The "Program" mode cannot be entered if the c o ffeemaker is in its "brew" cycle. Exiting "Set Program Time" Mode: "Set Program Time" may be exited in any of three ways: 1. Press the "Program Set" button. This will cause the coffeemaker to revert to its previous state. If it was OFF, it will return to the OFF position. If "Programmed", it will revert to this state, and so on. This is a safety feature. 2. Press any other button (except "Hours" or "Minutes"). "Set Program Time" will be exited and the function of that button will be executed. 3. Do nothing. If neither the "Hours" nor "Minutes" button is pressed for a period of five seconds, the "Set Program Time" mode will be exited and the programmed setting will be in effect.
Dec 28, 2010 | Cuisinart DGB-600 Coffee Maker
Coffee too weak what are normal knob settings
Function Knob For setting time of day, and auto on and auto off times. a. Auto On The Auto On feature is used to program the start time of the brew cycle. The auto on time can be set for any time, day or night. The “PM” indicator is displayed on the LCD for nighttime program times. b. Auto Off The Auto Off feature is used to shut off the coffeemaker at a preset time, anywhere from 0 to 4 hours. c. Program Set The Program Set function is used to set the time for the Auto On function. d. Brew The brew function is used to start the brew cycle directly. e. Clock Set Used to program the time of day. f. Audible Tone (not shown) The Brew Central™ Coffeemaker is equipped with an audible tone which will sound 5 times when the coffee has completed brewing (coffee will continue to stream from the filter for a few seconds after tone).
If yours is a Vienna Digital Coffee Maker please click the link below. it is manual of Coffee Maker, it would be helpful to in the future.. http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
Jan 20, 2010 | Saeco Vienna Digital Coffee Maker,...
No instructions on programming auto shut-off time (feature listed on box).
You have to use the "Auto-Off" feature, which is located on the same button as on/off:
The automatic shutoff time (ASO) can be
programmed to shut off immediately after
brewing (0:00) or up to 4 hours later. The
default shutoff time is 2 hours.
Press and hold the On/Off button to display
current shutoff time. To change the preset
time, press and hold the On/Off button until
the red power light and LCD display begin to
Set automatic shutoff mode. Set the time
you want coffee to begin brewing by
following the instructions in “Entering Time
Set Mode.”
When the coffeemaker shuts itself off, two
tones will sound.
NOTE: Automatic shutoff may be
programmed either before or during coffee
brewing. If you program the auto shutoff
time after brewing is completed the unit
will automatically account for elapsed time.
For example, if you set the auto shutoff for
40 minutes and 25 minutes have already
elapsed, the unit will shut off automatically
after 15 minutes (40 minutes minus the 25
elapsed equals 15 minutes).
-Tha Mp3 Doctor
Apr 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker won't brew
This one has two AUTO dial settings - AUTO-ON and AUTO-OFF. AUTO-OFF merely keeps the hot plate warm for a fixed period of time. AUTO-ON is the one that allows your coffeemaker to go off at the pre-programmed time in the morning.
If it is set to AUTO-ON, but is not brewing at the set time, unplug the machine for longer than 20 minutes. Then plug it back in, reset the clock, reset the prog time for a time that is just a few minutes into the future, and then test the auto-on feature.
If it stil ldoes not brew, just turn the machine to brew and press on. If it brews a pot, then your problem is electrical. If it doesn't brew a pot on the regular brew setting, then you either have: A) Calcium buildup/clog, or B) a hose leak (or worse).
To rule out the calcium buildup possibility, let half a caraffe worth of vinegar sit in the water reservoir for about an hour. After the hour, turn it to brew and press on, and brew the vinegar just as if it were coffee. If the vinegar goes through, your problem is solved.
Otherwise, call Cuisinart and find out if you are still in-warranty. Thep roduct has a 3-year warranty.
-Tha Mp3 Doctor
Mar 20, 2009 | Cuisinart CBC-00FR 12-Cup Coffee Maker
My Cuisinart coffee maker won't program start time.
Reset the coffeemaker by unplugging it for 20 minutes or longer - don't skimp on the time left unplugged.
Then plug the coffeemaker back in, reset the normal clock. Remember: It will display PM if it is on PM, but nothing if it is on AM.
Then hit the Program button. Hold in the "Hours" button for a few seconds and set the time you want the coffeemaker to go off in the morning. Hold in the "Minutes" button for a few seconds and change the minutes. Then hit the Program button again.
Now turn your coffeemaker to AUTO-ON - it will now go off at the set time.
Here is a link to the manual:
http://www.cuisinart.com/share/man/30_man.pdf
-Tha Mp3 Doctor
Mar 18, 2009 | Cuisinart DGB-300 Coffee Maker
Cuisinart grind/brew 10 cup coffeemaker
The part the manual doesn't mention is that, after you have set the program time, you have to press the program button one more time. THEN, set it to auto-on. Also, make sure that the clock is set for AM/PM as appropriate - it will display PM if it is set for PM, and will not give an indication either way if it is set for AM.
Voila!
-Tha Mp3 Doctor
Feb 12, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
After brewing coffee does not stay hot.
Unplug the coffeemaker for one full hour.
When you replug it, go to Auto-Off - change the time from "2:00" to "4:00", and then brew another pot. Immediately after the brewing is done, set the coffeemaker back to Auto-Off and see if your problem is resolved.
If not, it may have deeper problems. These coffeemakers have a 3-year warranty - call Cuisinart to see if you are still in-warranty.
-Tha Mp3 Doctor
Jan 31, 2009 | Cuisinart DCC-1200 Coffee Maker
Coffee maker shuts off too quickly
It seems this coffeemaker insists on shutting itself off after 4 hours,
or whatever "auto-off" time you've programmed in. The only work-around I've found is to switch it to "Brew" and cycle the power switch off and on every time you pour a cup. That will start a new
4-hour timer cycle. Since the pot's still hot, it will go quickly to the
"brewing done" state and render 5 beeps.
Jan 08, 2008 | Cuisinart DCC-1200 Coffee Maker
Black and decker coffee maker
what type of coffee maker? does it have a model number?
Dec 11, 2007 | Coffee Makers & Espresso Machines
Kenmore Elite 12-Cup Drip Coffeemaker, Brushed Aluminum Logo
61 people viewed this question
Top Kenmore Coffee Makers & Espresso Machines Experts
gbob59
ray gallant
Kardoc
Are you a Kenmore Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
