Left it drying overnight and in the morning checked that didn't finished, when turn it on nothing happened, power ok but nothing on display, power to PCB ok.
SOURCE: Asko T781 Electric Dryer Doesn't Turn On
Have you reset the cut out on the back? its a little black button that you push in until it clicks. If it does not click, then it probably wasnt the problem. The next most likely cause is a melted fuse holder inside the box on the rear where the power cord goes in. There is a bypass kit available to repair this problem from ASKO, as the fuses are not needed. If you are able to do some simple wiring, you can do this. Otherwise find an AUTHORIZED asko servicer and they will know what I'm talking about. Good luck!
SOURCE: dryer suddenly quit working
Having the same problem as above. Worked uptill yesterday. Now lights come on no activity. Please Help!!!
SOURCE: Dryer will not dry - drum will not turn
Just happened to mine also. The problem was that the Idler Pulley came loose from the drive belt. There is a switch on the idler pulley so that if there is no tension on it, the motor will not start and you will have the symptoms you describe. To reattach the Idler Pulley, remove the back plate surrounding the dryer exhaust. This will give you access to the Pulley. If the belt broke (unlikely with a new dryer such as yours), the fix is more involved. This dryer is the same as the Maytag MDE6700 - you can do a search for a service manual for that model and you can see the details. Hope this helps.
SOURCE: Admiral Dryer Designer Series. Nothing happens
probably not you needs to check the blower wheel to see if it is slipping. Then check for lint in the blower housing then check the fuse mounted on the side of the heating element.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Dryer not heating or drying.
Hello there:
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter
Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fus
