HEWLETT-PACKARD Hewlett Packard HP ProLiant ML110 G6 Special Server - Xeon X3430 .4 GHz (S7696035) Logo
A
Anonymous Posted on Jan 26, 2014
System doesn't get on after shut down
I have HP Proliant ML 110 G7 server. Once I have installed Windows Server 2008, and once I shut down the system. To start again I have to unplug the power cable and replug again to on the computer. Else the power button never works to wake up the system. Thanks
Meph1234
Level 2:
  • Expert 46 Answers
  • Posted on Jul 14, 2014
Meph1234
Expert
Level 2:
Answers
46
Questions
0
Helped
14427
Points
318
Check the system BIOS. I know that in certain HP systems you can disable the power button so that it doesnt do anything. It's to stop the system being accidently shut down
1 Related Answer
RyanFanMan
Ryan Nguyen
  • 342 Answers
  • Posted on Mar 20, 2011
SOURCE: how do i install RHEL5 on HP ProLiant ML 1100
are you going to do a clean install?
then you will have to access the boot device menu and select the cd drive or usb drive (whatever you are installin off of) and then install the Red Hat Linux hope this helps if not then please leave a comment
HP ProLiant ML110 G7 windows server 2008
...Is a second BIOS chip on the system board where a second copy of the BIOS and system configuration reside. If one of these fails (rare) then the second one is there so you can still boot and initiate a stable recovery.
My server is keeping booting and can't log in to windows
You issue could be both hardware and software related. The Blue Screen of Death is one that I don't like to see but can be easy to solve at times. First, I would recommend you recheck and hardware that was newly installed; memory cards, cables, etc. Verify they are connected or inserted correctly. Next, if this is a new install of Windows 2008, verify that your server meets the hardware captiablity for S2008. (Remember, this is a 64-bit os and you will need drivers if your server is 32-bit based.) You can find this out by inserting the Windows Server 2008 boot disc and run the Check System for Compatiablity function from the menu.
If you are certain that you have no hardware issues and the install was performed correctly, you may need to reinstall Server '08 and monitor the install for any exceptions that may occur.
Good Luck,
C2Solutions
I have installed windows 2008 server on HP ML 350 G3 and has refused to see the network
Hello, This could be many thing that causes this. 1. I would check the network properties to make sure the network ports are configured correclty. 2. Make sure the network services are turned on. 3. Make sure you have install the latest service pack for server 08 and your network drivers. Once done, reboot.
Good Luck
C2Solutions
Is HP ML 110 server compatible with 64-bit Windows 2008 R2 server?
Yes it should be.. Well the main important part is that you have a 64Bit processor installed on it.
So just make sure your processor is 64Bit then it will run 2008
Regards,
1helpful
I am using ProLiant ML110 Server i wont to use windows xp how to find the driver for xp
ProLiant ML 110 server series does not supports windows XP. It Support only the below OS.
  1. Windows 2000
  2. Windows 2003
  3. NetWare 5.1
  4. NetWare 6.0
  5. NetWare 6.5
  6. RHEL 2.1 (32 Bit)
  7. RHEL 4 (32 Bit)
  8. RHL 9
  9. SUSE Linux Enterprise Server 8
If you want to force this hardware to support windows XP, then download windows 2003 drivers which is equivalent to XP; but not the same as XP.
WINDOWS 2003 DRIVER LINK
Regards
Riztech
I have an Ml 110 G5 Server, But i could not find the VGA driver for the Win Xp , kindly assist thanks Justin
Hi, I m really sorry to say that but you have a Server Product and its built to run Windows Server Series on it (or Linux / Novell Netware).
This is the list of compatible Server list
Microsoft Windows Server 2003 Microsoft Windows Server 2003 for 64-bit Extended Systems Microsoft Windows Server 2008 Essential Business Microsoft Windows Server 2008 Foundation Edition Microsoft Windows Server 2008 R2 Microsoft Windows Server 2008 Small Business Microsoft Windows Server 2008 W32 Microsoft Windows Server 2008 x64 Novell NetWare 6.5 Red Hat Enterprise Linux 4 (AMD64/EM64T) Red Hat Enterprise Linux 4 (x86) Red Hat Enterprise Linux 5 Server (x86) Red Hat Enterprise Linux 5 Server (x86-64) SUSE Linux Enterprise Server 10 (AMD64/EM64T) SUSE Linux Enterprise Server 10 (x86) SUSE Linux Enterprise Server 9 (AMD64/EM64T) SUSE Linux Enterprise Server 9 (x86)
Here is the link for Drivers
Try to use the Driver for Windows 2003.
It has a Matrox VGA as I know. If you know which Matrox series you have, then Browse here for the Drives: Matrox Graphics Support. Make sure that you choose the Exact Driver software which suites the System.
Note: Not every product has the Driver Software for Windows XP.
Please rate the answer! Thanks for contacting Fixya!
I have tried x2 chassis and working memory but cannot get the full 12gb installed and runniing with Win 2008R2. it only takes x4 2GB sticks. Have tested all sticks in other machines and in same one...
Please see the below table to find you are on the right track.
Windows Server 2008 R2 Datacenter 2 TB
Windows Server 2008 R2 Enterprise 2 TB
Windows Server 2008 R2 for Itanium-Based Systems 2 TB
Windows Server 2008 R2 Foundation 8 GB
Windows Server 2008 R2 Standard 32 GB
Windows HPC Server 2008 R2 128 GB
Windows Web Server 2008 R2 32 GB
Machine no
Dear Jaiveer
There are a lot of softwares which can help you to get the server details, both hardware and software as well.
Like BelarcAdvisor and SystemInfo (System Information for Windows). You can download SystemIfon from the link : http://www.gtopala.com/siw-download.html
Cheers
Parveen
Top HEWLETT-PACKARD Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
