Question about iLO 3200 32 in. LCD Television
HDMI audio lags behind video on iLo 32" LCD television
I recently got a Samsung Blu-Ray player. I connected it to my 32" iLo LCD television via an HDMI cable. The picture looks great! However, the audio is about 1 second behind the video. This only happens with HDMI. The audio matches up through composite audio and through my home theater stereo system. Any suggestions?
Posted by theturner438 on
  • theturner438 Jun 03, 2009
    I need to add that did try connecting the Blu-Ray players to another LCD television throught the HDMI cable and the audio worked fine.
jc21680
    New Friend:
  • 44 Answers
Check the tvs settings menu. There should be a HDMI sound option which will fix the delay.
Posted on Nov 30, 2017
3 Related Answers
Anonymous
SOURCE: Ilo 32'' lcd television
call comcast and they will walk you through it at no charge
Posted on Nov 04, 2007
Ekse
  • 13434 Answers
SOURCE: HDMI problems
is the box set to use the hdmi? Sounds like a settings problem.
Posted on Oct 27, 2008
Anonymous
  • 87 Answers
SOURCE: i recently purchased a blu-ray player and when
That shouldn't make too much of a difference (or maybe im just being ignorant). If the bluray player was cheap, you may need to plug in via rca and then adjust the settings on your player to output to HDMI.
Hope this helps
Nick
Posted on Sep 02, 2009
Can't get any sound when playing discs through a blu ray player connected via a hdmi cable and DVI adapter.
The DVI adapter stops the audio. Use the audio out ports on the bluray player to connect an audio pair cable to the tv.
Jan 08, 2014 | Hyundai Televison & Video
No video via hdmi from blu ray
Have you attempted swapping out the HDMI cable for a different one? I recently had a similar problem and I determined that the HDMI cable was faulty. Now everything works fine.
Jul 26, 2012 | Televison & Video
I have a LG LCD TV 26LX2R and I recently bought a Sony Blu-Ray BCP-S580. If i connect them via Composite or Component cables i get ok video and audio. But when i connect them via HDMI i get excellent image...
I can't speak on whether or not the apple tv has such a setting but the Bluray players does. You go into the bluray player's settings and change the audio output.Your choices should be 2 ch possibly hdmi, bitstream, pcm, and auto. Try hdmi, 2 ch, and pcm because if you have it on auto you might not get sound via an hdmi cable and it's probably not bitstream but try bitstream if none of the others work.
Sep 20, 2011 | LG 26LX2R 26 in. HD-Ready LCD TV
I have Samsung HLN5065W and want to buy blu-ray player, also Samsung (BP1600). TV has no input for HDMI cable so is it not HD-ready? Will the blu-ray player display high resolution on my TV? Do I need...
ON YOUR TV YOU HAVE A DVI CONNECTER A BIG WHITE CONNECTER YOU CAN BUY A VDI TO HDMI ADAPTER YOU WILL ALSO NOTICE BEHIND YOUR TV CLOSE TO THE DVI CONNECTER THERES A INDICATION SAYING DVI AUDIO IN YOU MUST ALSO PLUG THE RED AND WHITE THIS IS FOR THE AUDIO BECAUSE DVI ONLY DOES THE VIDEO IT WILL WORK VERY WELL
Dec 25, 2009 | Samsung HLN5065W 50" Rear Projection...
My menu says dtv Currently unavailable. How do I use the HD feature on my Olevia LT32HV
Do you have a High Definition cable/satellite reciever or a Blu-Ray player? Does your tv have a HDMI input or component or DVi or all of those? Most newer HD components use the HDMI connection. The HDMI connection is a single cable that has both video and digital audio together. The component connection is a connector with three rca jacks that are red, green, and blue. Audio is connected seperately with this connection via red and green rca audio jacks or a digital audio connector. The last is a DVi connector that is found on computers. Some older HD tvs and components use this connection. There are adapters available to turn a DVi connection into a HDMI connection. So if your TV does not have a HDMI connection but your HD reciever does you can use and adapter but you will not have any audio this way without using a seperate connector for the audio.
Sep 16, 2009 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
Hookup diagram for Yamaha avr-863 receiver
It's the other way around.
Hook up the Cable box to the Amp; and the blu-ray to the amp, then connect amp to LCD.
you want to use the best available options for audio:
HDMI > Digital Optical > Digital Coax > standard RCA
And the similar for video:
HDMI > Component > SVideo > RCA cables
I would connect Blu-Ray via HDMI to Amp, and Cable box via HDMI to Amp. If your cable box does NOT support HDMI, but you have an HD package, ask your cable company for an upgraded box.
Mar 19, 2009 | Yamaha RX-V463 Receiver
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
iLO 3200 32 in. LCD Television Logo
138 people viewed this question
Top iLO Televison & Video Experts
Lee Hodgson
Lee Hodgson
CoppellTVRepair.com
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
