Multimedia Audio Controller
SOURCE: P5S800-VM multimedia audio controller driver
Hi Mairaj, please click the link posted below. This is Asus download site for your board P5S800-VM. Suggest you bookmark this page in case you need another driver.
http://support.asus.com/download/download.aspx?modelname=P5S800-VM&SLanguage=en-us
Creat a folder on your desktop & name it Audio.
Click the + sign next to Audio. If you are using Win XP home or Pro download,
Realtek ALC655 AC''97 Audio Driver V3.66 for Windows 98/ME/2000/XP(WHQL)/2003.
File size 24.17MB. Save file 32b366.zip in the folder you created.
The file 32b366.zip must be uncompressed before you can install it. If you do not have winzip please download this program for free from the link below. Install winzip into your PC.
http://www.download.com/WinZip/3000-2250_4-10003164.html?tag=pop.software
Once the file 32b366.zip has been uncompressed you can install the software.
If you have more questions feel free to ask.
Good Luck & have a Great Weekend!
Mike
SOURCE: P4GE-MX Multimedia audio Controller
If you're using Win XP/Win 2000/98se/NT4.0 you can download and use this audio controller driver for that motherboard: http://dlsvr03.asus.com/pub/ASUS/mb/sock478/p4ge-mx/ALC655.zip
SOURCE: driver for prescott 533
I think you're a little confused LUNISOZZI. Allow me to explain.
The term Prescott is a type of CPU. 533 is the (FSB), bus speed that the CPU can run at. There is no driver needed for the Intel Pent 4 Prescott 533 CPU. When updating windows there may be a revision update for the Pent 4 Prescott 533 CPU listed in windows update to the left under hardware. If you're CPU is not beeing seen by windows correctly than check windows update. If you're CPU is not working in on the Asus board, than remove the CPU & check the connecting pins on the CPU. One or more may be bent or broken. CPU may not be completely seated. Thermal grease was not added or too little added between the CPU & heat sink assembly.
Why don't you explain what it is that the CPU is or is not doing?
What is the motherboard not seeing? or windows ia not doing?
I can find a solution if you can explain.
Mike
SOURCE: NO AUDIO-MULTIMEDIA CONTROLLER
You need to install the audio driver of the board. Your board should come with a disc if not. go to ASUS website and downlaod the driver for your audio.
Hope this helps.
SOURCE: i need driver for multimedia controller PI845GVM
Hi thangamani20,
here you will find the driver's archive:
http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=507#
Greetings from Germany,
noris017
PS: Please don't forget to rate this solution after you've tested it out! Thanks in advance and have a nice day!
