Question about Dual Slide Controller 13398-c2 Motor Synchronous Velocity Ids Inc
Slide out won't move. Trouble shoot sheet says "Energize extend/retract switch" - HOw?
Slide only moves about 2inches in either direction. Error light says problem 8 - hall signal not present. HELP! PLEASE?!?
Posted by Juanita Greaves on
Trouble retracting last door slide You hear it try but it doesn't move. The first three slides worked fine
warning light something is wrong check track - motor for blockage glide damage motor weakness ==notify a rv shop for assistance with manuals or even trouble shooting info
Oct 02, 2018 | Cars & Trucks
Lens error
There is a possibility that a bit of grit or debris has got stuck in the retraction mechanism or the lens has been knocked out of alignment.
The camera will have switches inside to tell it when the lens is retracted or extended and if it doesn't make contact within the expected time then it will give this error.
If the there is no warrantee or you dont mind voiding it then I would suggest carefully disassembling the camera and turning the retraction motor by hand to see where the problem is.
Please comment again if you discover anything.
Good luck
Oct 19, 2007 | Nikon Coolpix 5200 Digital Camera
Ram on yard works 1 3/4 log splitter is extended but won`t retract...fluid level was low but is full now.
might have some air trapped in it. id loosen the rod end fitting on the cylinder just a little bit and try to retract it... be aware and put a rag over that fitting when you try to move it back it is gonna squirt a bit.it wont move until you purge the air out. then tighten the fitting back up. good luck
Mar 21, 2018 | Cars & Trucks
I have a 2003 Holiday rambler presidential 5th wheel and my bedroom slide will go out but won't come in with the switch. I replaced the switch and the battery and it still doesn't work. Help please.
You need to get to the motor and see if there is power going to it in both directions. Does it sound like the motor is running but nothing moving?
Apr 03, 2017 | Holiday Rambler RVs
Repair slide <living room is extended and won`t return>
Check to ensure nothing is blocking the slideout, its path or the gears of the motor. If you don't see a dimming of the lights when you push the retraction button or don't hear any motor noise check the fuse for the slideout motor. If all else fails there should be a manual slide retraction option somewhere that allows you to retract the slideout using a crank or a power drill. Check the owner's manual.
Sep 28, 2014 | Coachmen 2009 Concord 300 TS
FR350 won't shoot nails
Normally I would say you aren't using enough air pressure because somewhere around 80psi (every tool is different) will not be enough to fully retract the driver. At 110 you are fine so that is not the case. I doubt it is broken because a broken driver will still retract unless it broke near the piston. My guess is it needs the o-rings replaced but you can pull the top head and pull the driver out first to make sure. Parts and breakdowns can be found here as DeWalt owns Porter Cable.
PC FR350 diagram
Aug 19, 2012 | Porter Cable Air Tools & Compressors
Hi i had an e18 error appear and the lens was stuck. the lens is now going in and out but the focus is compleatley shot every thing is blured any ideas?? thanks
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon. Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jun 22, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Retractable Cord won't lock
When fully extended (you have to hold the cord in place since it won't lock), slide the rectractable device down the cord until it is butted up against the USB connector. You can use the mouse with no problems like this. When you are done, slide the retractor back to the middle of the cord and the ends will wind back in. It's not a perfect solution but at least makes the mouse usable.
Apr 23, 2009 | Targus (AMU02US) Mouse
Dual Slide Controller 13398-c2 Motor Synchronous Velocity Ids Inc Logo
287 people viewed this question
Top Dual Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Dual Video Game Console and Game Expert? Answer questions, earn points and help others
