Question about Toshiba XB1507 Receiver
Vr-208 kenwood code for dish network remote - Toshiba XB1507 Receiver
So I have a older kenwood vr-208 and just got a replacement remote for it rc-R0607 will this work and if so what 4 digit code do I use
The remote is nothing more than a device to change the contents display face. The code for the unit is embedded into the unit behind it, so the old code will work. It will not even notice you changed the remote control. If you bought a remote control for a different Kenwood audio, then it is a lottery. You can program a bespoke remote, they are set to one device, or a range of devices sharing the same code.
Kenwood Audio Remote Control New OEM Replacement ...
www.kenwood.newremotecontrol.com > KenwoodAudio
NEW Kenwood Audio & CD Remote Controls. ... VR-208, RC-R0607, A70-1194-05. VR-2080, RC-R0907, A70-1191-05. VR-209, RC-R0607, A70-1194-05. VR- ...
and also
http://www.remotecentral.com/cgi-bin/mboard/rc-remote/thread.cgi?2547
I Have 20.0 IR Dish Network Remote..Try To Program My Kenwood VR-500 Amp
Call 1 888 TW CABLE To Place Your Order For Time Warner Cable Service Wich Is The Best And Allways Will Be!
I Don't Know If They Will Still Buy You Out Of Your Contract Or Not So You Will Have To Ask!
Direct TV And DISH NETWORK Are Both SCAMS And You Fell For One Of Them ! They Are Ripping You Off!
Kenwood VR 208 Reciever remote code
So I have the same receiver and I have remote rc-r0607 and looking for the code that works
Need the 4 digit code for a kenwood vr-405 reciever with my kenwood rc-ro509 remote..stop working?
Here are some remote codes for Kenwood Receivers.
The codes are as follows: One of them should work
0027, 0077, 0313, 0186, 0314, 0356
Here is a link to a web site that has universal codes for remotes.
http://www.hifi-remote.com/ofa/codes-amp.shtml#amp
Hope this helps,
Best Regards,
Mark
2helpful
I have dish network and a dvr and cd disc changer i need to hook up to my kenwood vr-615
Hi shelleyhelle, I was reading over your post and see where you want toconnect the CD disc changer and you want to connect it to the Kenwood VR-615. Iwill send this link, http://www.retrevo.com/support/Kenwood-VR-615-Receivers-manual/id/480bh228/t/2/and it will help with the setup for the Kenwood VR-615 receiver.
1helpful
How do I connect my Kenwood VR-715 surround sound system, Dish Network receiver, and HD LCD TV together so the surround sound works? Can't figure out what goes in the input, the order of the connections or...
The best way to do this is to connect you dish network receiver is directly to the tv. Try to use the best video type possible. HDMI is the best, next is component and lastly is composite. This will take care of the video portion. Next, connect digital audio output to the Kenwood Receiver. I dont know what type of a digital audio output your dish box has, but your kenwood receiver has both optical and coaxial inputs so you should be fine there. Once you have both audio and video wired, change the inputs on both your tv and kenwood receiver to the inputs you are connected to. You might need to set up the kenwood to tell it that your running digital audio to it in the setup menus. Hopefully this helps, let me know if you need any clarification.
Good Luck
1helpful
What universal code to use with the VR-615 on dish network remote
We would be happy to help with that. Here is a list of someof the codes that we have for your Kenwood Receiver: 774, 795, 668, 691, 728, and 745.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codes for your Kenwood Receiver provided above. Press the pound (#) button, the mode light should flashthree times. Check that the code works by trying several different functions onthe remote to make sure it will properly operate your Kenwood Receiver. Keep in mindthat some codes may not be compatible with your equipment. If this is the case,please try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
I was trying to find the remote code for a kenwood vr-616
Kenwood radio tuners normally use one of the following remote codes:
025,066,068,071,and 075.
Sorry I don't know which is specific to vr-616.
3helpful
Remote dosen't work, trying to code my Sony RM-V302
there's a good chance it's the receiver and not the remote. Just fixed mine this afternoon with help from this blog.
http://blog.moertel.com/articles/2007/05/25/repairing-my-kenwood-a-v-receivers-remote-control-sensor
this worked on my kenwood vr-209. 10 others fixed their kenwood as well from the posts.
Jay
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
