Question about Frigidaire FWS445RF
Won't spin washer does not spin in spin cycle
3 Related Answers
chrispolkele
Electrolux
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Washer won't spin after rinse cycle
    Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
    Posted on Oct 02, 2012
    chrispolkele
    Electrolux
    • 4342 Answers
      Verified Fixya Pro
      SOURCE: washer won't spin on spin cycle but spins during other cyles
      Hello rylee1966 - From what you are describing, it sounds like the washer agitates, but it will not enter a high speed spin. If that is correct, more than likely there is a door switch failure. I will personally recommend contacting a professional to move forward accurately and to assist with the repair(s).
      Posted on Feb 25, 2013
      chrispolkele
      Electrolux
      • 4342 Answers
        Verified Fixya Pro
        SOURCE: my FAFW3511KR front load washer won't spin on the wash cycle. It has error code 11
        Hello Geri Witkowski - I understand that your washer displayed E11. Typically error code E11 indicates that either the unit is taking too long to fill with water or there is a possible leak.
        · Try resetting the unit by flipping the household circuit breaker off or unplugging it. Wait approximately ten minutes and restart unit.
        · Is the incoming water flow normal? If it is, does the fill water continue to enter the washer? If yes, disconnect power from the unit. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
        · If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
        If you have checked all of the above, the unit may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
        Posted on Mar 19, 2013
        Washer won't spin on spin cycle but spins during other cyles
        My washer won't spin when its on rinse cycle
        What is the complete model number of your unit?
        My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
        see this causes and fix it. God bless you
        Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
        Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
        Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
        Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
        Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
        Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
        Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
        Washer stays in wash cycle will not spin out i changed control board no help
        Isyour washing machine displaying an error code? If so, try using the owner's manual to decipher the code and you may beable to easily diagnose the problem. The problem could be as simple as the doorbeing slightly ajar, the machine is in pause mode, or the spin selector isstuck. Checkthe handy chart in the article Washingmachine won't advance to washer spin cycle for more possible reasons why your washingmachine won't advance to washer spin cycle-and some tricks for getting itworking again.
        5helpful
        2answers
        Washer will fill fill with water but doesn't start wash cycle
        it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
        Kenmore Automatic washer -110.24862300
        sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
        Washing Machines Logo
        Top Frigidaire Washing Machines Experts
        Dan Webster
        Dan Webster
        Gerry Harvey
        Gerry Harvey
        Michael Thomas
        Michael Thomas
        Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
