follow this steps and fix it. God bless you
Clutch
If the chainsaw chain does not engage the clutch assembly might be worn out. The clutch is similar to an automotive clutch. The chain sprocket is attached to the clutch drum and there are clutch pads underneath. As the pads wear out the clutch assembly no longer engages with the motor and the chain does not engage either.
Clutch Band kit
Chainsaws are equipped with a clutch band, a steel band that wraps around the clutch drum and is activated by the emergency stop lever. If the lever does not disengage the chain does not engage. Check to be sure the stop lever is disengaged. Adjust the clutch band if necessary.
Enter your model number to see parts for your chainsaw.
Help me find my model number
Drum Brake
Chainsaws are equipped with a clutch band drum brake, a steel band that wraps around the clutch drum and is activated by the emergency stop lever. If the lever does not disengage the chain does not engage. Check to be sure the stop lever is disengaged. If necessary, adjust the clutch band drum brake.
