Question about Denon Audio Players & Recorders
Sharp lc 26sa1e schematic diagram
My tv is stuck on audio without picture how to I change to audio and picture?
5 Related Answers
Anonymous
SOURCE: Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Posted on Feb 06, 2008
Anonymous
SOURCE: TV No Picture
My 32D40U would turn on for 5-10 seconds (Please Wait would appear) and the screen would go black. Sound Normal. It would also sometimes do this after running 5-10 minutes. I read somewhere that the inverter board would come loose and lose proper ground. I took the set apart, removed the board, and cleaned up the grounding points. I reassembled using some copper paste on the ground points and LockTite on the screws. I used some contact cleaner on all the connectors going to the board. I noticed two cables that are covered with copper shield tape where too tight at their connectors and repositioned the tape to give them some slack. The problem hasn't occurred since the fix.
Posted on Mar 22, 2008
Anonymous
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
Anonymous
  • 1077 Answers
SOURCE: My Sharp TV will only hear sound. No picture or images even from the tv menu setup option. Model# LC-19SB25U. About 1.5 yrs old. Converter box ok.
In most cases, you can reset the TV by leaving it unplugged for 30mins.
If this doesn't work, I believe the circuit board that supplies power to the screen maybe bad. They call this board a backlight inverter board. It would most likely cost more to repair than replace the TV .
Posted on May 27, 2009
Anonymous
SOURCE: hooked up my HDMI cable to my tv and i got picture
you willprobavblyfind in the menu of the tv or dvd somewhere to turn on sound for hdmi
Posted on Oct 29, 2009
My sharp aquos tv LC-60LE632U has picture but no sound, What can be done?
Check the audio 'output select' under the Systems Settings menus. The output may be set to 'variable'. Set it to 'fixed' so that the audio runs through the speakers.
Oct 12, 2014 | Sharp AQUOS LC-60LE632U 60" LED TV...
Schematic diagram of sharp tv
i need a schematic diagram of lc-32m400m-MBK
and H/LCD500142 Board allso
Aug 22, 2012 | Sharp Lc-32m400m 32" Multisystem Lcd Tv
Hi Folks, I've got a sharp LC-26SA1E.The sound problem I have is that it only has 3 sound levels.None, Loud(30) and house shaking loud (60).There is an error code that has come up in the top left hand...
While tv is off press and hold buttons on tv VOL(-), A/V and switch it on, release buttons after 5sec.
Suppose to get back to normal state then.
I checked on my old sharp lcd lc-32ra1e and worked.
Oct 29, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
I WANT TO KNOW HOW TO CONNECT MY PANASONIC MODEL SC-HT830V HOME THEATER SOUND SYSTEM TO A SHARP AQUOS MODEL LC-37D62U TELEVISION I NEED A WIRING DIAGRAM
U do not need a diagram-simply hook up red/white wires from audio output of sharp tv to audio input(tv) of panasonic unit.any questions contact us- [email protected]
Sep 10, 2009 | Televison & Video
Sharp LC 46D85U TV with NO SOUND (but perfect picture)
Sound like the TV has a defective audio board. Opening up the TV would most likely void the warranty.
It's best to take the TV back and exchange it for a new one. Personally, I wouldn't want to be stuck with a defective TV ( that just came out of the box ) that they are going to repair for you.
Jul 04, 2009 | Sharp AQUOS LC-42D85U 42 in. LCD TV
Sharp Aquos LC-32D44U stuck in ""Mono"
I dont know if this will work for you, but its worth a try. I had the same problem.
1. I changed to a station that was having the problem (an analog station with MONO displayed on the screen).
2. I unplugged the TV for about 15-20 minutes. (I was thinking maybe something needed to refresh, so thats why i unplugged the tv.)
3. I plugged the tv back in and voila. The station showed up as MONO then immediately swtiched to STEREO.
After that, i was able to use the AUDIO feature on the remote to actually change from MONO to SAP, etc.
Ive had my Sharp for about 5 months now, and thats the first time its happend to me. Luckily, i solved the problem...this time.
Hope it helps.
Feb 12, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Lc-19ad22u
where do you live?
is it connected to to RF or AV
Mar 12, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp LCD LC-46D64U
Dec 25, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp
www.asm-service-manual.com/List/TV%20List%20ASM.htm
Oct 22, 2007 | Sharp 32C-240 32" TV
16 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
