Excellent post, positive site. I have read your article on your website now. and I am also like your writing style, keep up the effective work. you also check this <a rel='nofollow' href="https://igfollowers.uk/"> buy instagram likes uk </a>
There is a thermostat in the bottom of the percolator that is broken. It would normally cut off the percolator heating element after the water reaches a certain temperature. It can be replaced but it takes a little skill. There is a video on eBay.
If you want to just unplug the percolator, time it for 1 minute per cup.
SOURCE: Farberware superfast perculator
Thanks for letting us know that there was no solution other than one I would have to come up with entirely on my own. My dad who is old school wouldn't let me give up so we took the thing apart and it was an easy fix. Take the 5/16 nut off the bottom. Pull the slide pins off the thermostat. Take the philips screw out of the support holding the thermostat in place. Use a sharp pointed knife and with the silver Aluminum cap flat on the bench, make a slice on one edge. Use the knife to pull the edge away from the plastic housing and the cap will pop off. Be careful not to loose the small piece of ceramic that lies in a small whole on top of the contact. Use a sharp knife to clean the contacts and check with an ohms meter or continuity light. If it makes a good contact, put it back together. It took my dad and me about 10 minutes to do the entire job. We looked for a part for 20 minutes. Good luck. Rick and Adam Schmitt of Maryland.
SOURCE: Farberware 12-cup percolator, #FCP 412-A, that does not work.
just resolder it, i did and it lasted a long time
part here
http://www.marbeck.com/percolator_home_farberware.html
SOURCE: FCP-240,280,412 Farberware Percolator, 3 Prong
HI, on the plug, is it the part that pluges into the wall or the pot. By the model # you have 3 China pots. On the pump just below the coffee basket, take a pair of pliers and put the basket on the tube , now just make small crimp just below the basket,just enough to make it out of round., you will make it so the crimp will not let the spring or basket go by. If it is the plug going into the wall just bend the 2 flat outward so the plug fits snug. Good luck . Ron
SOURCE: How do I make coffee in a Farberware 'superfast'
Hi 2 scoops of coffee to 3 cups. Then work it from there, to get it to your taste. It is done when it stops perking. When that happens the keepwarm element takes over until you unplug it. Good luck. Ron
SOURCE: looking the glass knob for the farberware FCP512
Hi. Go to eBay and search for farberware coffee pot parts. Good luck
