Question about Kyocera FS-C5030N Led Printer
Call service Code 4600 KYOCERA FS 8525 MFP - Kyocera FS-C5030N Led Printer
Posted by Barry Papa Yoro on
5 Related Answers
Anonymous
  • 66 Answers
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Posted on Mar 10, 2009
Anonymous
  • 300 Answers
SOURCE: CALL SERVICE 6000:0115785
Error 6000: is a fuser error 0115785 is your page count. You require a replacement fuser
Posted on Apr 14, 2009
versa093
  • 46 Answers
SOURCE: showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
Posted on Jun 12, 2009
n25an
Norman Davis
  • 622 Answers
SOURCE: What does mean Kyocera FS-3900DN Call Service 7410:0020192 ?
take out your paper tray... drum and developer and then pull out the paper
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 24, 2009
Anonymous
  • 241 Answers
SOURCE: I have a kyocera FS-2000D with error code: Call fo...
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
Posted on Jun 09, 2010
Can you use a Kyocera FK-170U fuser unit in place of a FK-150 fuser unit?
No the FK-170U fuser will not work in a printer that is compatible with the FK-150 fuser unit. I found a Kyocera FK-150 Fuser Unit available on Amazon here: https://www.amazon.com/Genuine-Kyocera-FK-150-302H493032-Kyocera/dp/B00GOO57M2 . Other sites have third-party replacements.
The FK-150 fuser is the correct fuser for the FS-1028MFP, FS-1128MFP, FS1350DN, among others. The FK-170U fits the following Kyocera printers: FS-1035 Mfp, FS-1135 Mfp, FS-1370DN and FS-1120D. There are a few other printers. The design changes means they can't be substituted.
I hope this helps.
Aug 01, 2018 | Kyocera Office Equipment & Supplies
What does the F246 code mean on my Kyocera FS 6530 MFP?
you will need to update your drivers and also the firmware of the machine.....firmware you might need to call a service provider
Apr 18, 2018 | Kyocera Office Equipment & Supplies
How to reset f 246 kyocera fS 8525
Upgrade your firmware on the machine (a tech will need to do that) and download the latest KX driver from kyocera support
Aug 31, 2014 | Kyocera FS Office Equipment & Supplies
Repair kyocera fs-1028 mfp machine failure call service c7990
developer unit fitted correctly or failure of developer unit .
May 21, 2014 | Kyocera Mita Kyocera FS-1028 MFP Laser...
Call service Code 4600 KYOCERA FS 8520 MFP
LSU cleaning motor error
When the LSU cleaning motor
is driven, an error signal is
detected continuously for 1 s.
Defective connector
cable or poor
contact in the connector.
Reinsert the connector. Also check for continuity
of the connector cable. If none, replace
the cable.
May 17, 2014 | Kyocera FS-C5030N Led Printer
Kyocera FS1118 mfp gives error code CF 040 after start up
do a google search for the service manual and then lookup the error code in the service manual
Jan 23, 2009 | Kyocera FS-1118 Printer
Kyocera FS-C5030N Led Printer Logo
177 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Timothy Van Der...
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
