Question about Weber 6492 Original Instant-Read Thermometer
How to open thermometer to change battery - Weber 6492 Original Instant-Read Thermometer
Lewis Shallcross
    New Friend:
You twist the head off counter clockwise. I was trying to pry it open, but of course that did not work. Good luck!
How to open thermometer to change battery - open-thermometer-change-battery-hnaefr33ibcmdn3mtkrgz3rx-2-0.jpg
Posted on Feb 03, 2015
  • Lewis Foster
    Lewis Foster Feb 17, 2019
    Thanks. Saved me breaking mine just now.
  • Chris Spears
    Chris Spears Apr 01, 2019
    Thanks from me too, tried prying open with a flat head screwdriver to no avail... Figured I was going to break it, so I set it aside, then googled. Thanks again Lewis Shallcross
bakenfat
Thanks Lewis! ????????
Posted on Jul 08, 2019
  • bakenfat
    bakenfat Jul 08, 2019
    ? Question marks are emojis lol :)
Can battery be changed on Polder instant read meat thermometer? If so,How?
Batteries can be changed on almost all instant read thermometers
go to POLDER.COM/ support/
then choose then choose
Thermometers
and then enter your model #.
This should take you to a detailed explanation. In general look at the unit and find the place to gently pry the cover apart. remove the batteries and replace with the same new style.
May 04, 2014 | Polder Home
How do you change batterie in thermoscam ear meter
on the side with the screen about 3/4 of the way to the bottom should be a tiny hole put a pen in it and push down to release the lock and open
Apr 07, 2013 | Braun IRT3020 Thermoscan Ear Thermometer
How do i change battery
1. Pull the battery cover off (away from the base) in a downward motion.
2. Install one new "CR2032" battery into
the battery compartment, with + facing
outward.
3. Replace and fasten the battery cover
securely.
Jan 12, 2013 | Lumiscope 2215L Digital Ear Thermometer
How do you change the battery? Mod. HM3
Replacing the batteries The thermometer is supplied with two 1.5 V type AA (LR 06). For best performance, we recommend Duracell ® alkaline batteries. Insert new batteries when the battery symbol appears on the display. Open the battery compartment. Remove the batteries and replace with new batteries, making sure the poles are in the right direction. Slide battery door back until it snaps in place. To protect the environment, dispose of empty batteries at appropriate collection sites according to national or local regulations.
Feb 09, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
How do you change the batteries?
Feb 08, 2011 | Braun Thermoscan Pro 4000 Ear Thermometer
How do i replace the battery in the theroscan plus braunn
Feb 03, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
I have a equitytime thermometer and can't find the instructions for it. I just changed the batteries and can't get the outdoor to send a signal to the indoor unit. where can I find the instructions for a...
Take the batteries out of both units (the base and the outdoor thermometer). Put the batteries back into the outdoor unit, and then put the batteries back into the base unit. This worked for me.
Apr 07, 2010 | Kitchen Appliances - Others
Weber 6492 Original Instant-Read Thermometer Logo
7,144 people viewed this question
Top Weber Home Experts
john h
Tom Chichester
Are you a Weber Home Expert? Answer questions, earn points and help others
