Question about Kenwood CT 401 Hi-Fi Stereo Dual Cassette Deck Single Dual Cassette Deck
Standby light comes on on amplifier but no sound
Stand by light comes on but no sound is coming through speakers and no other lights working
I have a sony s-master digital amplifier which will not power up: when I plug it i to power it takes about 30 minutes before the red standby light comes on but no other functions operate.
So the standby indicator never changes state? If so, more than likely, your amplifier has DC Offset(a damaged amplifier inside) which will keep the speakers off, and disable any use of the front or remote functions. If you are interested in having your Sony repaired, please refer to my website, audioserviceclinic.com. You may contact me there. Thank you.
Jul 11, 2015 | Audio Players & Recorders
No sound coming out of speakers but lights moving on board
The Efx 12 has two outputs monitor out as well as mix out ( XLR sockets ). If the level bars are moving its an indication that the mixer is working. Have you tried headphones out as well as monitor out.
What is your amplifier and speaker setup- you have not mentioned it at all.
Even if any PFL switch is on you won't get sound out of the speakers.
PFL stands for Post Fade Listen and when any of the 12 channel PFL switch is on only the headphone out put will work.
May 18, 2011 | Soundcraft Efx12 - 12 Channel Sound Board...
Fisher CA-885 Integrated Stereo Amplifier stuck in stand-by mode
Given the heat/cold cycles of the storage area along with humidity, I would first suspect poor solder connections. This is not unusual for units of this age. A general overhaul should restore this to operation. This should be a labor only repair unless the output STK is bad. These units are known for having poor connections at the voltage regulators which cause a DC voltage offset triggering the protection circuit. The overhaul should address this as well.
Keep us posted on your progress.
Dan
Jul 06, 2010 | Audio Players & Recorders
THE FUSES ARE NOT BLOWN AND THE FANS AND RED LIGHT COME ON BUT THERS NO SPEAKERS COME ON
first of all the reason why the speakers aren't working is because the red light isn't supposed to come on a green light is and if it is red that means something got fried or damaged
Jun 07, 2009 | Metrik Amplifiers MAX-802 Car Audio...
New behringer powered mixer, comes on, but doesn't hear anything.
Fan comes on with temperature rise. Not a problem if off till you start driving speakers loud.
Make sure standby switch is up. The slide switch is up to A/B.
The main fader iis up. Your input fader(s) are up. The trim controls are up enough. Inputs are plugged to input and not the inserts.
Be careful... this unit has a lot of power and can blow speakers.
Nov 23, 2008 | Behringer POWERED MIXER, 20 CH, 400 WTS...
500/1- Low ohm light
Disconnect the speaker wires from the amplifier's terminal block. If the low ohm light still comes on with no speaker wires connected, the amplifier will need to be repaired.
If the light no longer comes on, check the speakers and the wiring.
Jul 15, 2008 | Jl Audio 500/1 Car Audio Amplifier
Amp wont switch off of stand-by
Both units have a problem with the output section. In case 1, the outputs are likely to be shorted. In case 2, the outputs are open. The low level and distortion come from you driving the speakers with the driver section of the amp. Both units will need to see a service provider.
Dan
Apr 11, 2008 | NAD C320 2-Channel Amplifier
Top Kenwood Audio Players & Recorders Experts
Michael Thomas
Michael Thomas
Kardoc
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
