Russ
Try heating a cup of water for two minutes. I bet it doesn't. A sign of a magnetron being defective is a loud hum and no heating. Unit is then not economical to repair.
1. If your xbox 360 is in a confined space your not allowing the console to allow fresh air in and the heat out . The reason for your 360 being loud is the fans get louder and louder when the 360 system senses that the gpu heat sink is getting too hot. If you leave your xbox 360 on while you away for too long or if you play for too long the fans will get louder and louder . Solution : move the 360 to an open aired room if the problem persist shut off your xbox 360 and let it cool down a bit .
Hi, this is common in most microwaves. this abnormal noise is coming from a faulty Magnetron. this device is responsible for the heating process and, it is damaged and not heating at all at this point.Simply replace the Magnetron and, this unit will start to heat once more.
