Question about HP LASERJET P1006 Printer
Hp laserjet p1006 has stopped printing. When I connect usb-cable til pc, I get the msg: usb device not rekogniced
Have tried to download new drivers, uninnstall and install the printer. Tried on different pc's with win7 and vista. All have been working. Tried different usb-cable. Can it be some firmware to be downloaded and in case how? Is the usb-connection in the printer damaged? Is the only way to solve this problem to buy a new printer?
Don Eagan
    Master:
  • HP Master
  • 714 Answers
This may help. Before you disconnected the USB cable did you "disconnect" it using the icon in the system tray? If you did not, try cycling power to the computer with no USB cable for the printer connected. Sometimes when you unplug a USB cable while it is still "connected" to the device your computer will lose track of that USB port. I hope this helps you.
Posted on Nov 13, 2017
5 Related Answers
Anonymous
  • 352 Answers
SOURCE: not recognize usb printer hp laserjet 3050
Hi, I would suggest you update your printer drivers with fresh drivers, try this, follow instructions exactly as written:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Posted on Oct 21, 2008
Anonymous
SOURCE: My HP LaserJet 6L Won't Print on new HP/Vista PC
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook
Connect both ends from pc to 6L printer
Go to website to choose the correct O/S driver for installation
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=14974&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25476
Use virtual USB port005 for printer 6L
Bi-directional option can be ticked
Click apply and ok
Unplug and replug the USB cable
Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from http://www.bebo.com/andythoo
Posted on Nov 21, 2008
Anonymous
  • 54 Answers
SOURCE: HP Laserjet 1160 and Vista
Download update from HP on Vista.
Posted on Jul 11, 2009
komguy
Craig Gillette
  • 2306 Answers
SOURCE: HP LaserJet P1006 Printer will not print HELP!!!
wwww.partsurfer.hp.com under the support link will have a manual to download.
Posted on Sep 01, 2009
Anonymous
SOURCE: laptop will not print (wirelessly) to hp c7280
change driver for hp c7200 BT
Posted on Jan 15, 2010
I have an HP laserjet 1010. i got the paper jam
If you are getting correct test page without errors, simply unplug your printer's USB Connection from PC. uninstall Printer drivers and software. restart PC.. Re-Install New Copy of Drivers and Software.. THEN PLUG THE PRINTER USB CABLE TO PC.. try printing after proper driver is installed..
May 30, 2010 | HP LaserJet 1010 Printer
My hp laserjet p1006 will not print
Check the usb port, when connected to your pc, does your device manager revognize the device?. If it doesn't then check the cable and the port on the computer as well as on the printer. If you do see a connection, go to your printers and hardware folder and look for the driver right click on the driver and look for the properties, Once you have the properties window open look for the ports tab and check to see what port is selected.
Al
Nov 25, 2009 | HP LASERJET P1006 Printer
Sep 01, 2009 | HP LASERJET P1006 Printer
Hp laserjet p1006 printing jobs gets struck in printing queue
I know this problems in my part it was the hp driver.
My Solution is to use an compatible driver.
HP Laserjet 5 / or 6 standard windows driver.
After that i have not this problems.
The secound problem is that this printer have very less memory and big pages in a few times are not able to print.
Dec 25, 2008 | HP LASERJET P1006 Printer
Laserjet 1200
I would recommend that you perform a power cycle by unplugging the printer for 60 seconds then restarting your computer, logging back in....then plug your printer back into your computer, If that does not work I would also try going to www.hp.com clicking Software & Driver Downloads on your right corner of your browser of the HP website then typing in the product which is "Laserjet 1200" then choose your current operating system then download the full driver device.
Aug 20, 2008 | HP LaserJet 1200 Printer
HP laserjet 1100 won't print from Vista laptop
Which version of QuickBooks are you using? Anything older than 2008 will not work with vista.
Jul 08, 2008 | HP LaserJet 1100 Printer
Click apply and ok
Jan 20, 2008 | HP LaserJet 6L Printer
How to get a HP LaserJet 1018 to actually print something?
Yes it is a print driver problem, Unplug usb, delete all previous attemps at install, delete print software and drivers, Download and install correct driver from HP, plug in usb only when directed to do so.
Dec 18, 2007 | HP LaserJet 1018 Printer
HP LASERJET P1006 Printer Logo
94 people viewed this question
Ekse
efs_perpends
efs_perpends
