Question about Jabra BT125 Headset
Headset paired but doesnt function in ventrilo
I had this headset working in ventrilo on vista, but now it doesnt play thru any sounds or register anything thru the mic.  it is listed in my bluetooth menus, and all the output/input selections are set to use it.  i sometimes hear a few beeps in the ear piece, but no audio from ventrilo(it functions fine when i use the souncards ins/outs).  when i open ventrillo and press connect, the earpiece sounds like it turns on, but its just dead air.
its almost like its muted somewhere, but its not.  ive tried everything i can think of.  it is brand new, and worked all day sunday.  cant get it to make noise sense.
Posted by timesten2 on
  • crisxiii Feb 03, 2009
    i have the same problem. i heave nothing when i use it on ventrilo
  • SgtRenegade Mar 19, 2009
    insignia bluetooth headset, same problem
Anonymous
I'm currently having this same problem any solutions?
Posted on Jul 08, 2008
Anonymous
Did you ever figure out what was wrong. Mine is doing the same with my LG shine. I will have to take it in for service. You had the problem quite awhile ago. Hoping you got an answer.
Posted on Feb 17, 2008
Sound Still Play through Speakers when Headset Connected
Most computers will only pair this earpiece as a headset for voice calls. You need to make sure the headset is paired with your device as both a phone headset and media headset. Check your settings on your computer or smartphone to make sure it is paired properly to play media sound.
Apr 13, 2014 | LG HBS-700 Bluetooth Headset
Microphone not working
http://www.nikeexpert.com/
May 31, 2010 | Koss (10-16-004) Headphones
Jwin/iLuv i277 Bluepin i110 rx mode doesn't work
Hello,i ve a problem with bluepin rx mode,how can i fix this problem,thanks
May 04, 2010 | Jwin I1155 Portable DVD Player with Screen
My mic isnt working but i can hear out of my headset
If you are running Vista, make sure that you set your mic as the default. Then check on vent settings and make sure that your output setting are set for your head set. You can then test your headset inside of the settings tab.
Jan 27, 2010 | Genius HS-04SU Headset
LOGITECH 350 WONT WORK WITH VISTA. I CAN USE IT IN VENTRILO AND IT WORKS FINE, AND WHEN YOU USE THE TEST BUTTON UNDER THE PROPERTIES TAB YOU GET SOUND, BUT WHEN APPLICATIONS THAT ARE PRODUCING SOUND ARE...
You said you were disconnected so I said it again. You need to update your motherboard drivers. This will update your chipset drivers and hence the USB controllers. If you cant find your chipset drivers let me know the make and model of your motherboard and I will find them for you. I am positive that this will resolve your issue.
Sai.
Jan 09, 2010 | Logitech 250 Headset
No sound from bluetooth headset when paired w/ ps3 and audio set
the bluetooth headset is not compatible.get a compatible headset for ps3
Dec 03, 2009 | Sony Playstation 3 (PS3) Console
Microphone in Ventrilo is too low
try on another pc in sound recorder if working there then the headset is not the problem. try uninstalling the sound card and rebooting the pc.
may correct the issue.
Dec 29, 2008 | Logitech ClearChat Stereo Headset Headset
Cant talk at all
maybe you should try unmuting it lol or v+++
Dec 21, 2006 | Cyber Acoustics AC-201 Consumer Headset
Jabra BT125 Headset Logo
1,120 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
