Question about Maytag Neptune FAV6800AW Top Load Washer
Need to check pump for foriegn objects
SOURCE: I need an instruction manual for Maytag topload washer Neptune TL
Get the Service Manual this will help you diagnose issues with this washer. I found a Service repair manual on this site search for this; FAV6800 Manual. Check the postings and you will find a URL to the manual.
From another member a step by step to dump water from machine in diag mode ""One other thing I learned for those of you who don’t want to bail out the water in the tub. If you want to have the machine drain the excess water without bailing this should work. Turn the machine off and make sure the "locked door" light goes off. Then hold the "Spin" and "Enviro Plus" buttons at the same time for 3 seconds. "00" should then show up on the display. Then hit the "Delicate" button, then the “Pre-soak” button. This should activate the pump and get all the water out. Once the water is out hit the off button. You then may want to try the Spin cycle alone. These directions can be found on the Troubleshooting Manual found folded up behind the rear panel of the machine where the main electrical circuit board is located.""
Posted on Dec 15, 2008
SOURCE: i have a maytag neptune washer the water will not drain out of it
First drain as much water from the drum as possible and unplug from the outlet. Then there are 2 screws left and right under the front lower panel at floor level. Undo those two screws. Pry the front panel DOWN from the door panel. Once the lower panel is removed you will see the pump and pump filter on your right. The pump filter is to the left. It has a large turnscrew. Be ready with a pan or something to catch the water from the open filter! Screw this counterclockwise until it comes loose. You will now be able to remove the filter and all the debris. After cleaning, re-screw the turnscrew. Before you put back the front panel test that it is clear by doing a wash. If it still doesnt drain you must remove debris from the pump itself. The pump is between the pump filter and the pump motor on the right. Undo the white clips from the motor and the retaing clips attiching the filter to the metal washer body. Then turn the motor clockwise to separate it from the filter. Refit carefully after job is done. And fit outlet tube a correct height, not too deep. <courtesy tzotsi>
Posted on Mar 10, 2009
SOURCE: my maytag front loader will not drain water oe comes on the control panel
On the 9700s it's even easier - three screws on the front bottom panel below the door, then use your hand to unscrew the large round handle in the front center. When you can't unscrew any more, pull gently and the filter / catcher will come out.
It's amazing how much stuff mine held - 4 breastfeeding shields, a pencil, a pen, a fake mouse, and lots of grey gunk.
Screw it back in, put the panel back on, and you're in business.
Posted on May 04, 2009
Oct 19, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Apr 25, 2012 | Maytag Neptune Washer
Oct 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Sep 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Jun 15, 2009 | Maytag Neptune FAV6800AW Top Load Washer
May 25, 2009 | Maytag Washing Machines
Feb 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Nov 28, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Feb 27, 2008 | Washing Machines
323 people viewed this question
pump not pumping
